RaySchmidt
Wanted to see if anyone else is currently having or has had this issue in the past. My 3500 is maybe a few months old, however during one of my longer drives the check engine light came on. After reading it with a scanner and checking the info provided on the dash (such as temps, as well as where it tells you the DPF is regenerating) it came back saying there is something wrong with the DPF, and after talking to my dealership, I was told to bring the truck in asap for them to diagnose it and try and fix it. The first dealership I went to ended up charging me an insane amount of money to fix the issue, after holding onto the vehicle for longer than needed, however the problem was supposedly fixed. Not even a week later the check engine light came on again and it was the same exact problem. I brought it to a different dealership and after explaining the issue and what the first dealership did, was told they should not have charged me and that it was all covered by warranty (which is a problem on its own but not one Ill bring up now). The issue was once again supposedly fixed and I went about my business. However the light is now back AGAIN for the third time, and the scanner is giving me the exact same error code. Im bringing the truck in for the third time again to have it looked at, but I wanted to see if anyone else is experiencing or has experienced an issue like this or something similar, and how you went about correcting the issue. This has all happened in the timespan of around 2 weeks. I dont want this to become a normal occurrence, and I don't want to continue to have issues with the DPF or any issues with possibly breaking down. Thanks in advance for any help/response!
