2022 3500 Factory Wheel offerings
Brutal_HO
The Mad Irishman
Staff member
Douglas County, CO
Limited
Night Edition wheel shown is incorrect (note 6 lugs)
Longhorn
Laramie (Night Edition may not be available for order right now)
Bighorn
Tradesman
Thats dumb. The limited night edition 5 spoke you posted is what was on my 2019 Bighorn 1500. I highly doubt it is on a 3500. Ram probably messed up
This is a 3500 Limited night edition someone got the other day... https://hdrams.com/forum/index.php?...r-here-new-users-read-post-1.5385/post-122491
You're right. They had been the same as the shiny wheel, just black.
The site is showing the wrong wheel. I just looked at it again and it's only 6-lugs. ROFL.
Anyone have an idea what the 18x8 steel chrome clad wheels with Transforce A/T’s weigh each? Thanks!
I wish they offered a 19.5 wheel,, I run commercial tires (hate spending $1200 every 30-40k miles for tires) I get about 120,000 comfortably from a set of tires.. I don't run a street queen so my truck doesn't squat or look like a skate board--Function over form!
Does anybody know the specs of the factory 20" Night Edition wheel on the 22 3500?
Width?
Offset?
Weight rating?
TIA
Ram 3500 2022 6.7 TD​
– Generation: DS/DJ Facelift [2019 .. 2023] " data-original-title="Pickup Regular Cab, 2d" data-trigger="click" data-placement="bottom" data-html="true" style="color: rgb(190, 62, 29); text-decoration: none;"> " data-original-title="Pickup Crew Cab" data-trigger="click" data-placement="bottom" data-html="true" style="color: rgb(190, 62, 29); text-decoration: none;"> " data-original-title="Pickup Mega Cab" data-trigger="click" data-placement="bottom" data-html="true" style="color: rgb(190, 62, 29); text-decoration: none;">
– Power: 420 hp | 313 kW | 426 PS
– Engine: 6.7L, I6, Diesel
– Options: Lone Star, Big Horn, Tradesman, Laramie, Limited, Limited Longhorn
– Center Bore: 121.3 mm
– PCD: 8x165.1 (8x6.5)
– Wheel Fasteners: Lug nuts
– Wheel Tightening Torque: 190 Nm
– Thread Size: M14 x 1.5
– Trim Production: [2021 .. 2022]
" title="" style="cursor: pointer;">TireRim
Vehicle's recommended cold tire inflation pressure. It is measured in bars or PSI (pounds per square inch).
" data-original-title="" data-placement="bottom" title="Wheel Calculator" class="_popover" style="cursor: pointer;">
275/70R18 118T8Jx18 ET203.4 / 4.8
285/60R20 115H8Jx20 ET553.5 / 4.9
305/45R22 112V9Jx22 ET453.8 / 5.2
Vehicle's recommended cold tire inflation pressure. It is measured in bars or PSI (pounds per square inch).'s recommended cold tire inflation pressure. It is measured in bars or PSI (pounds per square inch).
Interesting to note the difference in offsets in the 2500 vs 3500 wheels, minor variance for the most part except for the 18" wheels, almost an inch difference in offset. Something to keep in mind if buying take-offs.
I suspect there is an error on that website as Ram publishes the same part numbers for both 2500 and 3500.
Ah! I thought it might have made sense due to bigger brake components or something. Appreciate the info.
For the tradesman anyway, tire options are 17” all season, 18” all season, and 18” on road/off road. Are the all seasons firestone ht and off roads the Firestone at? I optioned the off roads because I’ll need more than a highway tire and when they wear out (in a few weeks lol) I plan to get a better brand. Just curious because the tracker pic I can see falken on the side wall, know it may not be exact depiction though.
