2021-23 seats into 2026
sony224422
I have a friend who is parting out a power wagon, and has some nice seats/console.
I know right now the Alfa problems, but im more curious if the older seats would even work module wise. Are they able to be proxi aligned with the truck or do they need different modules?
I was thinking of changing door panels as well, I have the tradesman trim level and it leaves a lot to be desired
does anyone know if the modules in the tradesman seats will swap over to the power seats? Or do i need new modules and wiring for that?
i think im going to give this a whirl and see where i end up.
my thoughts at the moment are that the base seat components will work, but i will need to keep my stock modules. not sure if that means proxi alignment or not but i will see if ordering a wiring harness for the heated/cooled seats will at least get me close.
anyone have a picture of the connector under the seat for the heated/cooled front seat?
So far, I have found that I'll need a new wiring harness, which is expected, and new heat pads/module. looks like the motors are all the same, airbags are the same but ill probably swap them to be safe and the cooling motors are one rev newer, which makes me think they are updated. all in to change over should be 500 or so, maybe less.
the seat module is what concerns me as i do not have door memory, though i wouldn't mind adding it if i had to or could
