2020 2500 how to level on a budget
kristof
Should I use the spacers and brackets to level the front or different kit like new springs and shocks? If I have to pay couple of thousand of dollars to do it then I will stick with stock for now. Also should I replace anything in the back or just leave it as it is? 2020 2500 Tradesman HEMI.
Spacers are fine or just leave it because trusks should have a rake so you are not blinding others when towing…
So just the spacers with shocks brackets should do the job? If installed correctly they should not cause any problems?
I've ran spacers on mutiple rigs and they work just fine for what they are. If you simply want to level it's a great option and won't hurt anything.
With the long 4th gen control arms they have minimal effect on ride and are cheap. You will probably want to re-aim your headlights.
Do you tow often? Or haul heavy payload often?
That's the thing. I don't. I just love big trucks and most of the things I use it for is drive to work (mostly highway) and when we go to our property in other state. Then I put bunch of household items and tools in the back. I don't do any off-roading.
Go with a spacer, any of them up to 3" should work well in your application.
