2014 ram 2500 infor
Status
Not open for further replies.
Bucks2500
Looking at a 2014 ram 2500. What would the cost be to delete egr,dpf and def? Thank you for your info.
your going to get more info on fb or google than here.
if you can do your own work it would cost you $2k or so with a tune and you doing the exhaust swap. egr delete is another hundo.
Probably do it myself. I'm not going to put a tune on it. Just keeping it stock. Thank you for the info.
you can't do what your trying to do. it's either delete and tune, or leave it alone. if you remove emissions equipment without proper tuning, you'll have a 7500lb paperweight in short order.
Depending on your state, need to also think about what happens if you have to do emissions testing.
It doesn't work that way, you can't just take parts off without tuning the ECM.
Due to the EPA crack downs they have shut pretty much every tuner in the US down so there is that issue as well. Unless your truck is giving you issues you cannot resolve I'd just leave it alone.
plenty of tuning files to be had. that's not really the issue. staying under the radar is.
in any case, it seems the op needs to do some research in the process.
I guess I'll put a tune on it then. Not interested in more HP or torque. Has plenty for me.
I live in Alabama. No need to worry about emissions testing
Status
