Only white smoke when coolant temp reaches 193 degrees, sometimes it lingers, other times it dissipates.Smoke or steam? Does it linger or disappear rather quickly? White smoke would be oil, black smoke would be fuel. Steam would be head gasket.
Nope on both. Nothing in oil and nothing in coolant. I have heard this could be the start of an injector failure. PS, I do thank you for your replies. All info is a big help.Easy check sometimes for head gasket is get it to operating temp and watch for bubbles in the overflow tank. Is it losing coolant?
It has been deleted. No DEF. Know nothing about aftertreatments? It has 200,000 miles on it.This is my first Ram, and a search didn't turn up any easy results. Did the '13 have an aftertreatment? If yes, does yours still have one? Sometimes if the DEF system is injecting too much that can cause white/grey smoke also.
Gotcha. Looks like you may be right about the faulty injectors. The unburnt fuel smokes white/grey too.It has been deleted. No DEF. Know nothing about aftertreatments? It has 200,000 miles on it.
Yup. Completely forgot about the EGR cooler.Unlikely the turbo as you would have black smoke while accelerating/ driving. Injectors would hase all the time usually more when cold not just when the truck hits OP temp…. I would pick up some combustion gas test strips and test the coolant, to me it is either the headgasket or if it still has the egr cooler intact it may be cracked and allowing it to burn coolant
