Okay, so I'm 100% aware that with 20s I will have less sidewall and a stiffer tire. However, the only thing I really tow is my boat on a gooseneck trailer, maybe 15k all said. It doesn't sway and the pin weight isn't bar considering most of the weigjt is on the axles. I currently have 37s on 20s and I got no complaints. But I'm not towing every day (maybe 4x a month and 20 miles) and I like the look of 37s on 18s.
For you that have experienced the 18s with 37s, what do you think? Does the 1" sidewall difference really make that much of an issue?
Load capacity on the 18×37" tires is higher than the 20x37s by a couple hundred pounds each, same pressure.
Truck is a 3500 with the factory air.
