17” wheels on 2019 6.7 so
H3LZSN1P3R
You're doing it wrong
Canada
I did a quick search i could not find any info
is there enough clearance to put 17” alloy wheels on these trucks i know they offer 17” steels on the basic tradesman
My old Power Wagon wheels fit. Seemed snug to the calipers, but drove fine. Not enough offset for the 37s though.
Good to know thanks! Looks good btw... i want a snug fit around the caliper helps to keep the rims from packing with snow when plowing so i dont get the shake as if the tire is unbalanced
Depending on the wheels, they may have to be careful where they put the balance weights. They may need to place the weights closer to the center of the wheel. Definitely no stacking weights like some shops do.
yes, most fit fine. Check out CJC Offroad on instagram for pictures of many many trucks with 17" wheel setups.
Dont have instagram lol
If you want to view them anyway, you don't need anything more than a browser to view, only to post. If you use your search engine of choice and search for "Instagram CJC Offroad" or something along those lines, you should be taken to their feed and be able to scroll through the pics without needing an instagram account.
