Thorvald
Well this isn't off to a great start... I had the radio touch screen "freeze" the other week (full shutdown of truck fixed that for now) and Saturday got the Check Engine Light. Thankfully had a Kiwi ODBII reader with me so I was able to pull the codes and clear them to see if they come back.
The codes were P24B5 and P24C9.
According to DTCDecode:
P24B5
Particulate Matter Sensor Heater Control Circuit Low
Causes:
FUSED IGNITION SWITCH OUTPUT CIRCUIT (SCR RELAY 2 CIRCUIT) OPEN/HIGH RESISTANCE
FUSED IGNITION SWITCH OUTPUT CIRCUIT (SCR RELAY 2 CIRCUIT) SHORTED TO GROUND
FUSED IGNITION SWITCH OUTPUT CIRCUIT (SCR RELAY 2 CIRCUIT) SHORTED TO SENSOR GROUND CIRCUIT
PARTICULATE MATTER (PM) SENSOR
P24C9
Particulate Matter Sensor Temperature Circuit High
Causes:
FUSED IGNITION SWITCH OUTPUT CIRCUIT (SCR RELAY 2 CIRCUIT) SHORTED TO VOLTAGE
GROUND CIRCUIT SHORTED TO VOLTAGE
GROUND CIRCUIT OPEN/HIGH RESISTANCE
So hopefully just a "fluke" but will keep an eye on this.
P24B5
Causes:
P24C9
Causes:
