I have one of these I use. Can plug it into the 7 way plug in either the bed or bumper.
That's a nifty little doo-dad!I have one of these I use. Can plug it into the 7 way plug in either the bed or bumper.
Thanks. I don't have the aux switches but will check for the wires.Look at the large schematic in post #6. Blunt cut wires F are located near the spare tire. A few jumpers and you have power assuming you have the Aux switches.![]()
AUX pass-thru wiring.
Let me start by saying I am truly sorry for once again bringing this up. After I plug this harness in to the gray connector under dash the single wire is my pass thru #6? And than that loose wire can be hooked up directly to a device with in side the cab ? What do you all do with the extra...hdrams.com
The wires may be there even if you don't have the Aux switches and the connector under the dash that you would have to jumper.
Is the wire gauge heavy enough to support a viair compressor? I like the idea of plugging in using a cigarette style verses clamping to the battery terminals.I have one of these, too. I can reach the tires on the trailer for air ups.
Amazon.com: 12 Foot Heavy Duty Extension Cord with Cigarette Lighter Plug Socket, LDOPTO Car Interior Accessories Plug Adapter Outlet Car Splitter Adapter Replaceable fuse for car Inverter,Air Pump, Electric Cup : Automotive
Amazon.com: 12 Foot Heavy Duty Extension Cord with Cigarette Lighter Plug Socket, LDOPTO Car Interior Accessories Plug Adapter Outlet Car Splitter Adapter Replaceable fuse for car Inverter,Air Pump, Electric Cup : Automotivesmile.amazon.com
I use it for my portable viair compresser I purchased from Amazon.Is the wire gauge heavy enough to support a viair compressor? I like the idea of plugging in using a cigarette style verses clamping to the battery terminals.
Thanks. Max draw on that one is 14A. I have the 300P RVS and the max draw is 30A.I use it for my portable viair compresser I purchased from Amazon.
Amazon.com: Viair 00073 70P Heavy Duty Portable Compressor: Automotive
Buy Viair 00073 70P Heavy Duty Portable Compressor: Air Compressors & Inflators - Amazon.com ✓ FREE DELIVERY possible on eligible purchasessmile.amazon.com
