115VAC Cargo Switch / Inverter Switch
packmanno1
I am installing an aftermarket power inverter in my 2020 Tradesman and placing it under either the driver's seat or passenger's seat. The power inverter has a toggle on/off switch on the unit that I plan to bypass and run wiring to a toggle switch I'll install somewhere on the dash. I would really like to use the 115VAC Cargo switch (I don't currently have one). Can anybody tell me if it is possible to tap into the 115VAC Cargo switch (as pictured) to turn on/off the inverter when needed?
Also, I found the switch part number -
Inverter Switch - Mopar (6EM24TX7AC)​
Anybody know what the part number is for the panel this switch clips into?
Thanks
That switch must be only for trucks with an inverter in the bed I guess. I have the two outlets in the cab but I have no switch. Curious if that switch allows the power inverter to be on even if the ignition is off.
Any luck in finding the correct part number for the panel that holds the cargo 115v switch?
I'm working on a similar project and want everything to look factory.
I believe it is called "Bezel, Instrument Pannel Switch" and possible part number 6PG83TX7AA.
Can anyone verify that it is the correct part that holds the Instrument Panel Power Inverter Switch?
Thanks
Raul
The ignition still has to be on.
Thanks
Raul
I have a 2019 and these were the part numbers for the bezel and the switch.
6PG83TX7ABInstrument Panel Switch Bezel$8.411$8.41
6EM24TX7ACInverter Switch$10.531$10.53
I have them installed and the switch functions (lights up when pushed). I am trying to piece together the rest of the puzzle.
1. Is the factory wiring there for the cargo outlet?
2. Does is use the same inverter as the interior or is there a second one?
I will post back what I find.
1. Factory wiring will be there to a certain point. Likely different scenarios from truck to truck, so you'll have to do your own investigating.
2. Yes same inverter. 400W shared across all 115V outlets.
Also, it looks like the signals for the button and/or bed outlet go through the truck's data lines so it may not be possible to hook the button up to an aftermarket inverter.
