Help With Full Length Center Console Rear USBs
el_barto
Ok, so I installed a full length center console from a 2021 Laramie in my 2019 Power Wagon. Everything seems to work, EXCEPT the Wirless Charger (not a huge surprise, and don’t really care), and the rear USBs. Again, other things at the back of the console work, including the USB in the armrest, the light under the armrest, and the 115V AC plug at the back of the console. It sounds like others have had some difficulty getting the rear USB module to work as well, on their center console swaps.
I would like to get the rear USBs to work (power/charging at least).
The rear USB module that came with my console is p/n P68572629AA. It only has a 4-pin connector on the rear, no USB Micro Female connectors. It has the “charge only” (battery with lightning bolts) printed on the front, not the USB multimedia icon. There was a loose USB Micro -Male connector in the back of my console, not connected to anything.
I have found a couple of part numbers for other rear media hubs that have the USB trident logo on them, and they seem to have the 4-pin plug, plus dual USB Micro-Female connectors on the back.
P68402777AF
P68330429AF
Do we think that swapping one of these modules with the USB-Micro-female ports would do the trick? Maybe need to plug in the loose USB Micro-Male cable at the back of my Console?
Anything I need to activate in AlpaOBD?
Swapped the rear USB Media hub with one with rear USB-Micro-Female USB ports, and it works! Part number for the Rear USB Media hub I got: P68330429AD
I thought maybe it was the media hub itself that wasn’t working; but the new one didn’t seem to work without the USB plugged in (It did stay lit up for a bit after I disconnected the USB, but wasn’t powering).
It does NOT act as a media hub though, but that I don’t care about. I may swap the cases/face plates so it just has the charge icons…not that it really matters.
