OEM LED Marker Strip from the 3500 Dually Clear Lense
LanierCruzer
I had this mounted to my standard body 2500…it fits in right between the tailgate and bumper and gives you the 3 red led marker lights from the wide body. Bolt holes are there, you’ll need to get a couple nut clips from the dealer to make it work, once they go in you can’t get them out apparently. I had it wired up to the license plate light and frame for ground and it worked perfect and looks awesome. $50 shipped.
