Rear Axle TPMS 3500 SRW
NDanecker
At what tire pressure does the rear TPMS give alerts for low pressure? I have at 50 and while it rides better I cannot deal with the error message every time I get into truck. Thought I was stronger than that but nope. I am caving. LOL
TIA.
I think its 20% or so...put them at 66 and see if it goes away. Unfortunately unless you can convince a dealer(seen some they have been able to do this on DRW trucks) to adjust it you might be stuck with the light.
once the light comes on, you have to take it all the way to 80 to clear the error message. Then you can deflate them back down. I think below 65 it comes on again.
I run my rear (DRW) tires @ 45 psi. No warning.
When did 3500 get TPMS instead of TPIS?
TPIS is psi info only, no warnings, unlike a 2500.
