7.0 Cluster availability on a 2026 3500 Bighorn?
Thisnthat
Looked online and it looks like the "builder" only shows the 7.0 cluster available by selecting either the Level 2 Plus equipment group or the Safety package.
The level 2 equipment shows it as included, but apparently that is only available with the 6.4.
Before I ask a dealer, are there any other ways to add the cluster other than the two options above?
if you can find the dealer order guide online .. it will show whether or not its avaiable stand-alone. I was able to order the 7.0 cluster in my 2023 as a stand-alone option for $75 ... not sure if Ram still allows that without adding a package.
My 2026 bighorn 6.7 with Level 2 (non-plus) has the 7.0 cluster as part of the package.
I noticed several on the lots optioned out like yours as well...guess goes to show how much the online builder is incorrect
Sorry to bump but where can I see the dealer order guide online for both 1500 & 25?
Link to the HD guides in the first post of the thread linked below
Thanks, I will Study that carefully. Sorry for the stupid question, but is there a somewhat easy way to see, on that link, what exactly can or can't be added to each model? Like for example, where would I see which models can or can't have a Rambox or the Hemi engine (or anything else for that matter)?
Also, I Know this is off topic here, but would you Know if there's a link for something similar on the 1500 models?
I was able to find this, and this, but they mention fleets, so I don't Know if it is the same for regular purchases?
For 15's: https://www.stellantisfleet.com/con...cs/buyers-guide/2026/26DOMMOP_FBG_Ram1500.pdf[/URL]
For the 25-35's: https://www.stellantisfleet.com/con...-guide/2025/2025-RAM-2500-3500-HEAVY-DUTY.pdf[/URL]
Thanks again man!
