Can I take out my switches under my radio and replace them with the ones that have the auxiliary switches and my regular switches?
scottmayhew
Look here.
Keep in mind that thread is for a diesel truck that already has the Aux PDC because they have the electric cabin heaters.
OP hasn't indicated what truck he has.
You can switch the switch panel, but the AUX switches won't work unless you add all the wiring and relays in the PDC to your truck. My 2022 has the fues box, but none if the wiring and relays, so to make the AUX switches work you need to add all of that to this fues box. It is not plug and play!
