24 volt alternator ( auxiliary )
HarryN
I have been involved in some van projects where we added 24 and 48 volt alternators.
The 48 volt work, but it can be a lot more complex than 24 volt versions due to products availability.
Since my auxiliary battery pack will be 24 volt, gathering together info on what it takes to add on an after market alternator on the 25+ cummins / 3500.
The reason is that it is fairly easy to get 3 kW from a 24 volt alternator and much easier to move it around.
Right now just gathering information.
Thanks
WARNING - This is just information gathering and some of it will not be correct. Please double check before using anything and feel free to contribute anything related to the OEM setup for p/n's etc as this will lead to other parts, brackets, etc.
I have a 2024 Rebel 6.7 and it has 2 alternators. It was an option. Now I am trying to figure out how to harness that DC power for my RV trailer. What I mean is the wire with constant power on the 7 pin trailer connecter is maybe a 12 gauge which would limit the current going to the trailer to about 20 amps.
The wire in the 7 pin connector are just not useful for moving significant power from the truck to the trailer. I can run the math for you but you are right that it just is not useful.
If we target moving ( 100 amps ) x ( 12 volts ) ~ 1200 watts using DC - DC chargers, then the absolute minimum wire size ( reading from the left column of this ampacity charge ) is ~ 2 awg. This is possibly feasible, but disconnecting a live DC wire like that is - not ideal. The spark is substantial and can be quite damaging.
A more common approach is to use 120 vac, so 10 amps can easily be carried by 10 awg wire.
So put a 1500 or 2000 watt inverter in the truck, and run the wire to the RV trailer. Many trailers have a 120 vac charger in them that can be used to charge the battery.
This approach is very common in the van up-fit world that I play in.
Most consumer inverters are rated for "occasional duty" vs "continuous duty" so it is important to substantially oversize it.
It probably is not easy, but if you can get any photos of how the dual alternator it is implemented that would be interesting.
Most common approach is to run a separate set of cables to the RV with an Anderson style disconnect at the bumper and then use a larger DC-DC converter.
What do you want to know? There isn't much to learn from a photo with how they are integrated. Pass alternator has the field wire coming from a wire harness on the pass side and feeds directly to the pass battery, the 2nd alternator is on the drivers side and has it's field wire from that side and ties into the drivers side battery. Not much to it, both are ECM controlled.
This is what I do. My trailer system is 24v so I’m running a Victron Orion XS1400 in the trailer because it can do any 12 or 24v on either side at a max of 50A. There’s a 2AWG run from my truck battery to the Anderson connector on the bumper, and at the Orion it hits a fuse block that drops it to 4AWG as that’s the largest wire that fits in the Orion. It also leaves me room to add a second Orion if I want to send 100A back there.
In the summer this thing cranks out all day long at 50A as I run the trailer ACs off of my battery when I drive. I also highly recommend the Orion XS models as they’re extremely efficient. There’s only a 13W loss at 700W throughput, so it never gets hot enough that you can’t put your hand on it. Find an inverter setup that’s anywhere close to that efficient.
I've only ever read good things about the Orion XS. If I wasn't installing a 24V alternator on my van (it gets here tomorrow :p) that's the route I would be going.
I thought that the output was limited to ~25A when going 12 to 24V due to the 50A inlet limit, and the only way to get 50A @ 24V was to go 24-24. Are you seeing 50A 12-12?
It’s 50A max in or out. So 12/12 you get 50A in and out at 12V (really 14V nominal, so 700W), 24/24 you get 50 24V (really 28V nominal, so 1400W), 12/24 you get 50A in at 12V and 25A out at 24V, 24/12 you get 25A in at 24V and 50A out at 12V.
I ran the plain Orion XS 12V only model for over a year in the last trailer and it did great as well.
I should also add that my 12V stuff in the trailer is running off an older Orion 24/12 70A converter. It’s rock solid, but less efficient than an Orion XS and provides no data. It was also less than half the price.
Rumor is there will be a 70A Orion XS coming out soon.
Ok, that's what I was thinking. When you said it cranks out all day at 50A I was thinking you meant output, which didn't make sense for 12-24.
I am pretty sure a 70A unit would sell very well.
Yeah, I can see how my wording was confusing.
If a 70A version comes out I’d be tempted to swap out my current one. Of course, with 1200W of solar on my roofs with plans for more, and Furion Chill Cubes for ACs I’ve barely needed the 50A.
Here is a battery to battery charger that is rated for nominal 120 amps ( in ) of 12 volt, 24 volt out in case that is interesting.
It has settings to use it at lower power settings, as well as the ability to reverse the current flow if needed to keep the starter battery charged.
Sterling sure is proud of their products, but they also get great reviews. The reverse flow is appealing too.
Definitely want a lot of airflow around that sucker.
Thanks.
There are two general approaches to dual alternator setups:
1) Buy from the factor with dual 12 volt alternators.
- This uses the engine controller to run both of them.
- It is a great option, but typically you can't replace one of them with an aftermarket 24 volt or 48 volt alternator.
2) Buy a single 12 volt alternator from the factory
- Find the required brackets and an after market alternator that fits
- Depending on the vehicle, this can require some fairly specialized tools and very high torque levels
________________
The reason I started this thread was to help find the tools and brackets needed to install ( 2 )
My assumption is that the after market 24 volt alternator would use similar brackets, belts, etc to ( 1 )
I have been collecting possible p/ns but am not sure about them. Will post them this week.
The diagrams I have found do not refer to the 220 vs 240 volt alternators, just a part number call out.
On their older model, the heating problem is most definitely true. In fact I don't recommend the older models at all.
A few people have installed these newer models on promaster and transit vans and they run surprisingly cool.
I am a big believer in running electronics at 50 - 70% when at all possible for a long life, not matter the brand.
One of the reasons I am attracted to this model is that it accepts 2 awg wire in all of the ports.
I agree that the reverse charging feature is pretty neat.
____________________
For a run as long as a (front of the truck ) to ( almost the back of a trailer ), the inverter method can be quite interesting.
If the trailer already has a 120 volt charger built in, then the inverter method can potentially be a lower cost approach in terms of total installation cost.
Inverters are obviously not as efficient as the latest BTB chargers, and have a standby power draw so those are downsides that need to be dealt with.
____________
I think part of sterling's price challenge is that they moved production from ( I think Taiwan ) to China as a cost savings measure, so they have been hit hard by tariffs.
Victron is building in India so there is more political leverage for them.
Hopefully at some point, they will both set up mfg operations in North America to reduce this, at least on some products.
