Dauntless 392
Fellas,
I had a few years away from the forum; career, law school, son, struggling with PTSD and hearing suicide has taken more people from me than explosive (I was an EOD Tech “bomb tech”).
[Edit 2/4/26]
The build name: “Dauntless 392”
“Dauntless” was the name of an A10 warthog flight in Afghanistan, and a story for another day “392”…. Well, as wagon owners you should all know its significance.
The theme is a naturally aspirated muscle truck, “a quiet professional” with a low mild rumble at idle, but acceleration emits the iconic deep throaty V8 muscle inside. Quick, fast, but focused on even torque distribution and embarrassing same year deleted diesels (for about x4 the cost).
Installed Modifications
*I logged hours of data on engine related mods, feel free to ask about anything.
Bold Text = Highly recommend
Undecided or Actively Looking
This build, minus the undecided/actively looking section, simulates at 605hp/552tq using 91 at the pump .
Surprisingly (to me), 637hp/582tq were the numbers produced by my e85 simulation. It has lower combustibility than 91-octane, which helps hit closer to MBT over KR limitations.
But at a ~30% less efficiency in mpg, but a lot cheaper around here. I’d want new injectors and a pump if necessary; but I’m entertaining this.
[Edit 2/4/26]
- KC PW Light Bar w/ (x4) 8” KC SlimLite
- Durastep M2 Lumstep “power step ups”
- BW flip ball gooseneck hitch
- Timbren Suspension Helpers
- Borla S-Type cat-back exhaust
- S&B Cold Air Intake
- Pulsar edge
- Brian Tooley Stage 2 Camshaft Master Kit
- Includes: Johnson Performance Axle Oiled Lifters (MDS Delete), VVT locker, news gaskets, bolts, rods,
- American Racing headers, long pipe, cat
- HP Tuners unlocked PCM (dyno available)
- 90mm throttle body
- Need better power distribution “center”
- Need better aux switch solution.
