LED headlight/fog light bulb
Units
South Ms.
I know you can change the settings on the truck using JScan for going from factory halogen to led headlamps, which I have the ability to do. Question is, if I were use just led bulbs in my current housings, would I need the anti flicker device for them or can I just change the settings in JScan for them (headlights and fogs) to function correctly? Thanks for the input.
Just switch to LED settings it’s much better than any antiflicker garbage.
