Z flash on 2022-2023 HD trucks
Eli77657
Nov 9, 2022
Has anyone used the Z flash on 2022 or 2023 2500? I’m fixin to order one for myself want to know if it still works their website only lists till 2021
mountainears
Mar 29, 2022
Looks like maybe light flashing? If you have the factory VSIM or add it you can activate the wig wag feature. Not all the combos they are offering but it’s factory :)
Eli77657
Nov 9, 2022
I already ordered it and my plan is to find out if it works adding it to the long list of parts
I like this because we can do custom (and hardwire it to the aux buttons )
el_barto
May 25, 2020
What does it do / used for?
I have one for my 2019; relatively easy way to adjust tire diameter to correct the speedometer, adjust TPMS threshold, prevent fog lights from dropping out when turn on high beams, etc. You can do these things with a computer and alfaOBD too but this is a bit easier for beginners/no computer needed.
I would get the bypass cabe that plugs in to the can bus over the SGW bypass module so you dont have to pull the dash apart
Eli77657
Nov 9, 2022
Where can I get that ? Care to share some links? I already ordered the SGW bypass Module but I’d rather not have to break everything when I go to the dealership for service
Eli77657
Nov 9, 2022
That’s out of stock any alternatives
KEXC
Nov 12, 2023
I am currently in the process of getting this thing to work, I have a ram 3500 2022 with the 12” touchscreen and my issue is that when I plug the obd2 port in my stereo/radio it glitches every 5 seconds or so. Also, it does not come with any light patterns, you need to plug it into a windows computer (Mac does not work). Still waiting to get it plugged into a computer but I’m a little worried about the glitching with the screen when plugged in. Btw this was installed by a professional.
