The HOFF
Don't Hassel me
- Joined
- May 8, 2019
Not going with a dually. Talked myself out of it again.Sure doesn’t look like a dually. Not with that maximum payload number. Something’s off.
You’re going to be overloaded again. Your final payload will be around 3400lbs.Not going with a dually. Talked myself out of it again.
Just don’t want it to blow on the 2500. Sales manager has confirmed on another one I’ll be around 4100 so should be enough.Wow. I so wish we could get CAT scale numbers for the broke truck. I thought okay he is just driving it down the road a bit. But then he asked for someone to tow it 114 miles.
Yikes.
Here’s the scoop. I am a road warrior 80% of the time and I pull out RV 10-20% of time no more than 150 miles. If I ever start traveling up in Colorado mountains or over 150-200 miles I’ll upgrade again. Reason I don’t go over 150 miles because it’s 4 trips. Have to come back and get the boat too. I hit a fluke bump in the road which already is doing repairs on road too and won’t be going that way soon so I think the SWB will work for our family needs. My buddy has one ton dually but him and his 44 Ft is up in Idaho. Not us.Sure doesn’t look like a dually. Not with that maximum payload number. Something’s off.
distance is irrelevant. As you found out. Things can happen any time any where. And for a variety of reasons. Most accidents happen within 5 miles of home.Here’s the scoop. I am a road warrior 80% of the time and I pull out RV 10-20% of time no more than 150 miles. If I ever start traveling up in Colorado mountains or over 150-200 miles I’ll upgrade again. Reason I don’t go over 150 miles because it’s 4 trips. Have to come back and get the boat too. I hit a fluke bump in the road which already is doing repairs on road too and won’t be going that way soon so I think the SWB will work for our family needs. My buddy has one ton dually but him and his 44 Ft is up in Idaho. Not us.
You won’t be at 4100. That’s MAX payload for a srw 3500. It changes by configuration. If you look at door stickers from people with a similar configuration you’ll see you’ll be closer to 3400.Just don’t want it to blow on the 2500. Sales manager has confirmed on another one I’ll be around 4100 so should be enough.
Ram box and mega cab really eat in to payload. About as much as the diesel over the gas engine does.Without the HO Cummins, my fully loaded up Laramie has 3919 payload. I suspect yours will come in around that number or 200# less if you go HO.
Here are the window sticker and payload sticker for my truck. You are looking at a Mega cab truck single rear wheel so I think your truck will be a bit heavier than mine so payload will be a bit less. You really need to do some math to be sure you won't be overloaded again.
The is the only numbers I can find on it.Off topic....Can you look at your bed step and see what the part number is on it? It should be all the way up where the bed step mounts to the frame. I have been trying to get the part number for a 3500 bed step for quite some time. I would greatly appreciate it.
Don-T.....THANK YOU SIR!!!.....the 82215842AC.....is the part number!.....You're AWESOME!!!The is the only numbers I can find on it.
