What's on your Aux Switches
1954 M37
Apr 7, 2021
Anyone used an Aux switch as a kill switch? If so, what circuit (fuel pump, etc.) did you tap into and where?
I dont think it would work well mine can sometimes drop out when cranking so it could cause a no start issue
Big Baloo
Jun 13, 2022
Alabama
Planned:
Aux 1 - Transfer Tank Solenoid
Aux 2 - Rear Quick Disconnect for Car Carrier Winch Solenoid
Aux 3 - Possible Train Horn
Aux 4 - Empty;
Aux 5 - Empty;
Aux 6 - Annoying Travel Companion Ejector Seat
John Jensen
Feb 11, 2020
Update
Auxiliary Switch #1 - Baja Designs 20" LED bar in the front bumper
Auxiliary Switch #2 - Nilight Rear LED Lights under the rear bumper
Auxiliary Switch #3 - Nanny Control Switch - Shuts off the ESC, TCS & ABS
Auxiliary Switch #4 - KC Hilites Underhood Lights
Auxiliary Switch #5 - Vacant
Auxiliary Switch #6 - Vacant
Auxiliary Switch #3 - Nanny Control Switch, Shuts off the ESC, TCS & ABS
How did you do this one john?
We used to do it in the jeeps by interrupting power to the traction control module then it was off till next restart
John Jensen
Feb 11, 2020
For my 1500 Eco I made a switch system. For my 2020 HO I bought an Abel system
Abel Nanny Kill Switch
Edit:
If you order one be sure to tell Abel you are using an Aux Switch as he will modify for plug and play to an Aux Switch.
My order showed "Modified for Aux Switch control"
John Jensen
Feb 11, 2020
Now thats a nifty idea i might make one its
Go for it! Easy to do.
Here's a copy of my 1500's switch diagram that uses 30 amp fuse F26. For a 2019+ HD you would use 40 amp fuse D11. For any truck with aux switches just ignore the remote switch on my diagram and use an aux switch. When I did this Abel was not in the picture, however, his system is similar to mine. The hardest part is modifying the fuse. If you find a fuse adapter that replaces the "modified fuse" process let me know.
  • 22a-ESC-TCS Modification - JFJ.pdf
Big Baloo
Jun 13, 2022
Alabama
Planned:
Aux 4 - Empty;
Aux 5 - Empty;
Update to planned:
Aux 2 - 2 Wheel Low Unlock (BDDiesel)
Aux 3 - Furrion Monitor
Aux 4 - Possible Train Horn
Aux 5 - Empty
Aux 6 - Rear Quick Disconnect for Winch Connection
Need to get these done before hunting season...
Aux 1 - Aux Reverse Lights
Aux 2 - Winch Solenoid
Aux 3 - Air Compressor
Aux 4 - Empty
Aux 5 - Empty
Aux 6 - Trailer TPMS booster
Considering a nanny kill switch and a 2-Lo mod...but still unsure as I never needed either on my 2018.
Rallyguy44
Dec 5, 2022
For adding reverse lights is there a way to get them hooked to an aux switch without having to run a wire all the way to the back of the truck? I’ve seen a few mentions of a plug above the spare tire but don’t understand how to tie that to one of the switches. Thanks!
MtnRider
Feb 5, 2020
Georgia
Those blunt cut wires are a dead end, your better off just running a new wire.
1651Naismith
Jan 1, 2020
Colorado Springs, CO
I thought there were details in this thread or a separate thread on the reverse lights. I found out about that option after I ran mine the length of the truck -- which was a PITA.
There are wiring schematics on the Ram Body Builder website that can assist you in making it work. There should also be some wiring diagrams in this thread. @John Jensen has a pretty good write-up on it.
Why is that? I used them and it was a very easy install to do so. You do have to do a little wiring under the dash, but it makes it pretty clean for up to 2 pre-ran circuits are the rear bumper.
MtnRider
Feb 5, 2020
Georgia
Because it is probably easier for him to wire from the aux output in the engine bay straight back vs running it back into the cab and trying to get the correct pins etc to interface with the existing connector. Then you will still need to extend the ends at the rear to get them to reach the lights.
Having done both I would still use the blunt cut wires for the rear bumper if there were no plans to use the IGN+ or Batt+ back there. It’s not difficult.
John Jensen
Feb 11, 2020
Here's what I did
  • 01b-Nilight Backup LED Bars-Wiring.pdf
elephantrider
Hydraulic Lifter Crew
Sep 3, 2019
aux 1 light bar
aux 2 fogs
aux 3 rear floods
aux 4 empty
aux 5 air pump for ttain horns
aux 6 empty
406Linetrash
Oct 4, 2020
Split my loom for my light bar. It has amber led “marker” lights between the row.
Aux 1 Lightbar
Aux 2 ambers
