Don-T
- Joined
- Feb 4, 2019
You found the answer before I could get back to you. Glad you did.Nevermind. You were correct.
According to that TFL article it will require a flash so at the very least, a dealership will likely have to be involved for software.So looked under my truck and it looks like the trailer pressure sensor connection is there. Its the same 4 wire plug in the same location mentioned in the diagram i posted above. Hopefully the trailer tire pressure module will simply be a plug and play item.
What TFL article are you referring to?According to that TFL article it will require a flash so at the very least, a dealership will likely have to be involved for software.
I have been down this road with Chrysler before, and I will be very surprised if there is more than ZERO support for early buyers on this matter. They are likely to just wash their hands of it. I hope I'm wrong.
I wonder when the Mopar trailer camera becomes available if it'll be as nightmarish as the TTPM is going to be?
regal2800 when did you order you truck , I ordered mine 2-8-19 , I looked for the trailer pressure sensor connection , not sure if I could see it.
I ordered my 3500 Dually, in mid June, expected by September. My order specifically purchased the trailer camera connection. No mention of TPMS though. BTW is it TPMS or TTPMS, I would really like the temperature info. Hoping my truck is standard with it.
Here is what’s in the brochure. I’m hoping mine has it. My sales rep said it’s in the towing pkg, if not they will paying for the upgrade.
From dealership sales guy.Where did you get that brochure, the dealership?
This is what my dealer told me today as well. My unit is expected in September and more then likely will not have TTPMS... I’m sad about that. When available it’s probably going to be an up charge for the option.As @Gondul recommended, get that in writing because The Fast Lane Truck contacted Ram about adding the TTPMS feature, but Ram said it won't be easy.
For those with the early build trucks without TTPM, getting the feature added back on won’t be as simple as a plug-and-play MOPAR kit either. "TTPM could be added but it would consist of vehicle configuration changes, software flashes, wiring, and module replacement,” said a Ram spokesman. “It can be done, but it is not a Mopar kit that’s plug and play.”"
