Yes, been on a couple of months. No issuesAnyone have a Roll and Lock bed cover. Dave Smith Ram in Idaho pushes them in their parts dept for new Rams. Any other brands you like? Thanks
I was able to modify the rails so I could remount them. I cut the rail off so it was a little short of the box and mounted it using four T-nuts. First photo shows where I added a loop so the end of the strap was easier to reach. By the way, my truck didn't have the adjustable tie-down hooks when I bought it used. I added tie-down hooks from a Tundra. They are a perfect fit.Do any of these options work with the factory rail / tie down hooks? Thanks.
That's great info. Thank you. And also helpful to know I can get spare tie-downs from a Tundra!I was able to modify the rails so I could remount them. I cut the rail off so it was a little short of the box and mounted it using four T-nuts. First photo shows where I added a loop so the end of the strap was easier to reach. By the way, my truck didn't have the adjustable tie-down hooks when I bought it used. I added tie-down hooks from a Tundra. They are a perfect fit.
That looks fantastic! It looks like the perfect setup with the factory rails still in there.I ended up with the BAK Revolver X4S and I am pretty impressed with the fit and the quality of it. It went together rather easily, seems pretty stout and still allows the use of the rails and tie down anchors that came with the Rambox. Here's a couple pics that I snapped. I really like the way the rails for the cover slide into the factory Rambox rails. Install tip for those that end up with this model, mark the washers then loosen the rear 2-3 bolts a bit to allow more room for the seal to slide in.
What model RAM do you have? I want to get a Retrax Pro MX too but the Retrax website says it’s incompatible with my new body style 2021 2500 limited. But then, etrailer.com says certain models (like RetraxOne) would fit on my truck. Confused. Any insights appreciated.I just put a Retrax Pro MX on mine and am very happy with it - very high quality, straightforward installation, easy to use, locks in any open position. Can't compare it to the Roll n Lock, but I had a Peragon on my F-150 and this is much, much better.
Thanks. That's helpful.Laramie 3500 6’4 bed. Had retrax on my 2017 but had Dave Smith install Roll and Lock on new 2022. I like it better. Easy to slide. Got upgrade model for $1900 installed. Little less money than retracts. We will see. It stays open most of time due to fifth wheel towing. They say base model gets lines on top if left open. Save 500 bucks if closed most of time and get base model.
Did you get the straps to tighten in the rails? I don't know if I'm doing it wrong, but the bolt bottoms out before it gets anywhere near tight. I'm also wondering if I have the wrong straps. The buckle end is wrong. I contacted Bak and they sent the correct ends, but maybe I have the wrong hardware at the other end too?I ended up with the BAK Revolver X4S and I am pretty impressed with the fit and the quality of it. It went together rather easily, seems pretty stout and still allows the use of the rails and tie down anchors that came with the Rambox. Here's a couple pics that I snapped. I really like the way the rails for the cover slide into the factory Rambox rails. Install tip for those that end up with this model, mark the washers then loosen the rear 2-3 bolts a bit to allow more room for the seal to slide in.
