Step Bars
ernursing21
Jan 16, 2019
Does any know if the 2018 Ram 2500 step (nerf) bars will fit the new 2019 Ram 2500? Is the bolt on pattern the same since the Cab did not change?
Thanks
DevilDodge
Nov 21, 2018
Age
46
Central Pennsylvania
I do not know for sure...but I would be surprised if they didn't. Since nothing was done to the cab floor...I do not see why they would have changed this.
But, I haven't seen anything specific.
D
Deleted member 80
Guest
I would guess the same, BUT there are enough frame and mount changes to make me wary. Not a gamble I'd take without better info.
Shane
May 2, 2019
Is there any update or new experience with regards to this question?
hutchman
Mar 12, 2019
I have a set of 2018 side steps on mine and they fit fine......BUT, Amp steps for a 2018 gas truck will not fit on a 2019 gas truck. Amp steps for a 2018 truck will fit if your 2019 is a diesel. But not on a gas truck.
Nordic28
Mar 28, 2019
Rough Country nerf steps bolted on perfectly in the factory holes.20190506_181418.jpg
1stStrike
May 10, 2019
I bought some Tyger step bars of Amazon. They were listed as fitting a 2010-2019 so i decided to take a risk and bought them. They fit for the most part. The only issue seems to be the center section of the bar were only one of the bolt holes lines up.
Bighorn
May 9, 2019
They are the factory Mopar flares for a 2018 (and earlier). Common on the off road package trucks. I purchased them from a local Ram dealer. Aside from removing some snap on/off plastic trim that came on my truck, then cutting off two alignment tabs on the flares, they went right on. I like the looks of a black flare with the other black parts on the truck.
TogaLock77
May 5, 2020
I tried the Rough Country drop steps and they weren't even close despite advertising as such. The bracket were a good inch off both vertically and horizontally.
