Removing Rearview Mirror Covers on a Limited
Razzman
Jan 10, 2021
Has anyone removed the rearview mirror base covers on a 19-20 Limited? I need to access to run power for the dash cam and cannot figure out what needs to happen to remove. I've seen posts on older models but they're different. Thanks
RockaRhyme
Dec 18, 2021
pry out the plastic trim piece directly above the mirror with whatever you’ve got laying around. A trim removal tool works well. Then just pull the housing down with your hands.
Razzman
Jan 10, 2021
Awesome thanks! I'll check it out in a couple days and see how that works.
Razzman
Jan 10, 2021
So here's the mirror housing in question, I'm assuming your referring to the vertical section right behind the mirror? I have trim tools and nothing gets between the pieces so I figured it must be starting around the mirror stem hole. No matter how hard I try it doesn't budge and feels like it's going to break!
RockaRhyme
Dec 18, 2021
you got it. pry from the mirror hole until you think its gonna break and then pry a little harder
Jimmy07
Re-coding from an easy-chair
Apr 5, 2020
There’s some more detailed pics of taking it apart in the following thread-
Brewbud
Brewmeister Meisterbrew
Aug 21, 2020
SoCal
I didn't know about giving the assembly a twist to remove it. Thank you
