Recalls Thread
Thread to post Recalls.
Please do not discuss recalls in this thread, post ONLY the recall info and links.
Y76 Grid Heater Relay potential Fire
REPORT:
Manufacturer Name : Chrysler (FCA US, LLC)
Submission Date : OCT 14, 2021
NHTSA Recall No. : 21V-798
Manufacturer Recall No. : Y76
10/15/2021
New Safety Recall Advanced Communication – Y76
FCA US LLC (FCA US) has announced a safety recall on certain 2021 and 2022 Model Year (DJ) Ram 2500 Pickup, (D2) Ram 3500 Pickup, (DD) Ram 3500 Cab Chassis and (DP) Ram 4500/5500 Cab Chassis vehicles equipped with a 6.7L Cummins Engine.
REASON FOR THIS SAFETY RECALL Some of the above vehicles may experience an engine compartment fire originating from an electrical short in the Intake Air Heater Relay, which can potentially lead to a vehicle fire with the ignition in the “ON” or “OFF” position. A vehicle fire can result in increased risk of occupant injury and/or injury to persons outside the vehicle, as well as property damage. It is advised to exercise the following precautions until the vehicle has the final repair completed: do not park these vehicles inside of buildings or structures, or near other vehicles.
SERVICE ACTION The remedy for this condition is not currently available. Dealers will be notified of the launch of this safety recall by way of established communication methods. We ask that you please take the time to ensure that your personnel are aware of this communication and are prepared to execute a customer friendly process for inquiries regarding involved vehicles.
Safety Recall Y76 / NHTSA 21V-798 Intake Air Heater Relay
October 2021
Dealer Service Instructions for: Safety Recall Y76 / NHTSA 21V-798 Intake Air Heater Relay
Remedy Available
2021 - 2022 (DJ) Ram 2500 Pickup
NOTE: This recall applies only to the above vehicles equipped with a 6.7L Cummins Engine (sales code ETN, ETL, ETM).
NOTE: Some vehicles above may have been identified as not involved in this recall and therefore have been excluded from this recall.
IMPORTANT: Some of the involved vehicles may be in dealer new vehicle inventory. Federal law requires you to complete this recall service on these vehicles before retail delivery. Dealers should also consider this requirement to apply to used vehicle inventory and should perform this recall on vehicles in for service. Involved vehicles can be determined by using the VIP inquiry process.
Subject
The intake air heater relay on about 137,946 of the above vehicles may experience an engine compartment fire originating from an electrical short in the Intake Air Heater Relay, which can potentially lead to a vehicle fire with the ignition in the “ON” or “OFF” position. A vehicle fire can result in increased risk of occupant injury and/or injury to persons outside the vehicle, as well as property damage.
Repair
For all vehicles involved, check Engine Run Hours in the Instrument Panel Cluster. If total engine hours are LESS than 600, perform Section A: Grid Heater Temperature Test Procedure. If the total engine hours are GREATER than 600, this recall can be marked complete on 2022 model year vehicles and can be returned to the customer.
Additionally, for 2021 Model Year vehicles, built before 01/08/2021, review service history for a previous Y08 recall completion. If Y08 remedy was not previously completed, perform Section C: Intake Air Heater Relay RTV Application Procedure. If Y08 was previously completed, close the recall.
If the grid heater relay exceeds the specified surface temperature, contact STAR Center for a replacement relay and additional directions. Reference Section B: Grid Heater Relay Replacement Procedure if relay replacement is directed by STAR Center.
Bed Step W24 / W44 / W54
Safety Recall W54 / NHTSA 20V-207 Bed Step
The bed step on about 8,700 of the above vehicles may fail in certain angular or side-load loading conditions. If a sufficient side-load is applied to the bed step, its mounting bracket may fracture and cause the bed step to suddenly and unexpectedly fail while in use, which can increase the risk of an injury to the user.
WHY DOES MY VEHICLE NEED REPAIRS?
The bed step on your vehicle [1] may fail in certain angular or side-load loading conditions. If a sufficient side-load is applied to the bed step, its mounting bracket may fracture and cause the bed step to suddenly and unexpectedly fail while in use, which can increase the risk of an injury to the user.
68RFE W03
February 2020
Safety Recall W03 / NHTSA 20V-043 Transmission Valve Body
The transmission on about 85,000 of the above vehicles may experience a buildup of pressure and heat inside the transmission which may result in transmission fluid being expelled from the dipstick tube. Expelled transmission fluid may come in contact with the turbocharger, or other ignition sources within the engine compartment and lead to a vehicle fire. A vehicle fire can result in increased risk of occupant injury and injury to persons outside the vehicle, as well as property damage.
02/01/2020
New Safety Recall Advanced Communication – W03
FCA US LLC (FCA US) has announced a safety recall on certain 2019 Model Year through 2020 Model Year (DJ) RAM 2500 Pickup and (D2) RAM 3500 Pickup vehicles equipped with a 6-Speed Automatic 68RFE Transmission (sales Code DG7).
VINs identified as being involved in this campaign are currently live and searchable. Stop sale is in effect for the above-identified vehicles.
Vehicles impacted by a stop sale are eligible for reimbursement allowance through the Recall Floorplan Reimbursement Policy (RFPRP), which can be requested upon recall claim submission.
IMPORTANT: Some of the involved vehicles may be in dealer new vehicle inventory. Federal law requires you to complete this recall service on these vehicles before retail delivery. Violation of this requirement by a dealer could result in a civil penalty of up to $21,000 per vehicle. Involved vehicles can be determined by using the VIP inquiry process.
REASON FOR THIS SAFETY RECALL Some of the above vehicles may experience a buildup of pressure and heat inside the transmission which may result in transmission fluid being expelled from the dipstick tube. Expelled transmission fluid may come in contact with the turbocharger, or other ignition sources within the engine compartment and lead to a vehicle fire. A vehicle fire can result in increased risk of occupant injury and injury to persons outside the vehicle, as well as property damage.
SERVICE ACTION FCA US will conduct a voluntary safety recall to will replace the transmission valve body separator plate and reprogram the Powertrain Control Module (PCM). Dealers will be notified of the launch of this safety recall by way of established communication methods. This recall is estimated to launch in 1st Quarter of 2020. We ask that you please take the time to ensure that your personnel are aware of this communication and are prepared to execute a customer friendly process for inquiries regarding involved vehicles.
CP4 HPFP Recall campaign Y78 / NHTSA 21V-880
UPDATED: Parts Available MAY 10 2022. Call dealer to schedule pre-parts order inspection.
Part 573 Safety Recall Report
Submission Date : NOV 12, 2021
NHTSA Recall No. : 21V-880
Manufacturer Recall No. : Y78
11/18/2021
New Safety Recall Advanced Communication – Y78
FCA US LLC (FCA US) has announced a safety recall on certain 2019 through 2020 Model Year (D2) Ram 3500 Pickup, (DD) Ram 3500 Cab Chassis, (DJ) Ram 2500 Pickup and (DP) Ram 4500/5500 Cab Chassis vehicles equipped with a 6.7L diesel engine.
REASON FOR THIS SAFETY RECALL Some of the above vehicles may have been built with a High Pressure Fuel Pump (HPFP) that could fail prematurely. A high pressure fuel pump failure may introduce internally failed component debris into the fuel system potentially causing fuel starvation. Vehicle occupants may notice a Malfunction Indicator Lamp illuminating, a fuel leak, abnormal engine noise, or a change in drive quality. Fuel starvation may result in an unexpected loss of motive power, which can cause vehicle crash without prior warning.
SERVICE ACTION FCA US will conduct a voluntary safety recall to replace the HPFP, update the Powertrain Control Module (PCM) software, and inspect and, if necessary, replace additional fuel system components. The remedy for this condition is not currently available. Dealers will be notified of the launch of this safety recall by way of established communication methods. This recall is estimated to launch in 1st Quarter of 2022. We ask that you please take the time to ensure that your personnel are aware of this communication and are prepared to execute a customer friendly process for inquiries regarding involved vehicles
Here’s two advanced communications for it:
Wiper Arm Recall Z08 / NHTSA 22V-035
Report
Some 2019-2020 MY Ram 3500 vehicles may have been built with one or both windshield wiper arms with an improperly formed wiper arm head joint. The suspect period began on April 27, 2019, when a new wiper nut was introduced into production, and ended on March 9, 2020, when the new wiper nut was no longer used in production. The suspect period was determined using vehicle production records. Similar vehicles not included in the recall were manufactured before or after the suspect period.
Recall Notice:
The wiper arm on your vehicle [1] may have been built with an improperly formed wiper arm head joint that did not fully form the splines of the head joint on the wiper arm. This can allow the joint to strip and result in the wiper arm failing to operate properly when the system is activated. Prior to complete wiper system failure, the driver may notice that one or both wipers do not clear the windshield properly or that the wipers are not in their proper rest positions. An improperly functioning wiper system may, in certain circumstances, lead to diminished road visibility which can cause a vehicle crash without prior warning.
ESC Safety Recall
Safety Recall Z20 / NHTSA 22V-140
Electronic Stability Control
2019 - 2022 (DJ) Ram 2500 Pickup
2019 - 2022 (DF) Ram 3500 10K LB. CAB Chassis
2021 - 2022 (WD) Dodge Durango
The Antilock Brake System (ABS) control module software on about 370,437 of
the above vehicles may prevent the Electronic Stability Control ("ESC") telltale
lamp from properly displaying under certain conditions. Unexpected performance
of the ESC system with no warning to the driver can cause a vehicle crash without
prior warning.
Repair: Reprogram the ABS Control Module with the latest software level.
Revision 1 March 2022
Seat Belt Safety recall W67 / 20V-580.
The front seat belt retractor on these vehicles may have been built with an improperly formed wave disc which has reduced internal friction resulting in reduced energy management capability. A seat belt retractor with reduced energy management capability may not perform as expected during a crash.
Report:
09/25/2020
New Safety Recall Advanced Communication – W67
wrvond
Sep 20, 2023
West Virginia, USA
Received an email this morning concerning my December vehicle health report stating this recall pertains to my VIN. The narrative only specifies RAM 1500 Classics so I'm not sure what's going on...
jsalbre
Oct 29, 2019
ID
