Bocephus
Feb 13, 2021
@RamCares, a mod shut down the page where we are waiting on the latest updates on the cp4 service solution that you have been posting on. Could you please comment hear if any updates occur
*** PLEASE READ THIS ENTIRE POST BEFORE ASKING QUESTIONS IN THE THREAD ***
UPDATE for 2019 owners - dealers are now accepting Y78 for 2019 trucks.
Update 6-19-2022: Updated TSB and dealer letter regarding only 2019 trucks that have an open PCM flash recall (older updates) can have the recall completed at this time.
Reports and member experiences lead us to believe the CP3 PCM flash has the potential to brick a 2019 PCM with current flash code.
Here's the full TSB doc. This is available on NHTSA https://www.nhtsa.gov/recalls
Here's the related letter to dealers to perform those open recalls first. I think that's why 2019 are getting rejected.​
Update 6-7-2022: Someone posted the letter indicating 2019 fix is not yet available. https://hdrams.com/forum/index.php?...-2020-parts-available-may-10.6321/post-198906
[MOD: HPFP Recall issued]
CP4.2 pumps will be replaced by a CP3 version pump with an adapter plate/ring similar to the aftermarket offerings.
UNDER NO CIRCUMSTANCES WILL ANY 2019-2020 TRUCK WITH A CP4 HAVE ANOTHER CP4 INSTALLED FOR ANY PUMP FAILURES. PUMP VERSION DOESN'T MATTER FOR RECALL OR FAILURE REPLACEMENT.
[MOD: Compliments of @Jimmy07 :]
Here’s two advanced communications for it:
Revised TSB for CP4 failure replacement kit with CP3.3 pump retrofit: https://drive.google.com/file/d/1MQAFhqEr5mnCJ1VzIjOQBHzcqSEV260H/view
[MOD: CP3.3 retrofit kit]
index.php
New pump tag:
Base Y78 Recall pump kit:
Full failure mode additional parts:
Im interested in seeing what they have to say as i can see they are currently viewing the thread, however i don't have any worries ir concern over the CP4.2 in my truck
gimmie11s
Mar 30, 2021
Hi all,
Thank you for your patience. A solution will be available by the end of third quarter. We will keep you updated as new information becomes available.
Sarah
Ram Cares
Could be any day now, if that's the case. Good news!
