OEM factory rock sliders
michael
Mar 26, 2021
Anyone have thoughts on OEM factory rock rails on 2021 Ram Power wagon. ? Curious on quality compared to frame-mounted White Knuckle rock rails.
Are the factory rock rails frame mounted or attached to body ?
pdavey
Apr 29, 2019
I have the WK sliders and you could lift the truck with them.
From the looks of the ones they are putting on the 75th anniversary edition from the factory they won't be nearly as strong.
That said jeeps have used pinch weld sliders for some time and they do provide some degree of protection but I wouldn't call them sliders.
I guess the good news on the factory ones is they won't weigh as heavily on the truck as the WK or maple off road ones will.
michael
Mar 26, 2021
Thanks, i was just able to look at the rock rail on the 75th anniversary power wagon. The rail appears to be just cosmetic. Made of some kind of plastic or composite. This would not do the job if needed out on the trail.
Airmousam
Feb 24, 2021
They are not plastic for sure...40lbs each...they mount to the body and pinch welds
pdavey
Apr 29, 2019
So at 40 lbs they must be sheet metal or aluminum.
Definitely meant for the casual glance or mall crawling not heavy offroading.
jadmt
Aug 29, 2020
Age
65
Missoula
They are similar to jeep jk rubicon rails and those are much tougher than people think, now granted a pw weighs ~1500lbs more give or take but these are still light years ahead in protection compared to iem tube steps or nothing. Still no replacement for real sliders for true rock crawling Tho but for what many do they are great.
sdu
Nov 18, 2020
Did you get them? I'm interested. I want something to protect against rocks thrown up by the tires without losing ground clearance.
jadmt
Aug 29, 2020
Age
65
Missoula
have not found any close yet.
Airmousam
Feb 24, 2021
I sold mine but when I had them they offer little protection from crap being thrown up from the tires...better than nothing I suppose
michael
Mar 26, 2021
I am still on the fence on getting the factory rails. I dont intend to do any rock climbing but if i ever get into a tight spot where it will rub, I would hope it would have a decent degree of protection like WK.
Airmousam
Feb 24, 2021
They'll protect even pretty hard rubs and they look really cool...they're 40lbs each..would have kept them, but wife 5' 2" and hated them
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
40lb each is heavy. if that’s true, they’re beefy.
For example: 1.75” x.120 wall 1020 DOM tubing weighs right at 2lb per linear foot and it has a yield strength of 80,000psi, IIRC. That material what I build rock sliders and roll cages out of.
AnthonyD1978
Jul 23, 2020
Arizona Mountains
For reference, my white knuckle sliders are about 130lb each if I remember correctly.
Rockcrawlindude
Jan 1, 2021
Georgia USA
Yea that’s about right. They’re 1/4” wall main tubes and .120 or .188 secondary tubes depending on how you order them, I believe
sceptre155
Mar 19, 2021
They mount to the backside of the rockers, and thru the pinch weld. The brackets I believe are Steel, and the boards are Aluminum.
Wobly
Mar 19, 2021
Colorado Springs, CO
I wish you would have posted these pictures earlier on Saturday! I took mine off and sold them and it took me a few minutes to figure out how to get the pinch weld bolts out. I had to reach my fingers in the hole, find the bolt head, use a wobbler extension and a 10mm socket to remove them. They were surprisingly stout, but not close to what I would consider a "real" rock slider.
