I’ve been dealing with this issue longer that I’ve wanted to it’s bone stock other then a delete
Recently replaced rail pressure sensor,front 4 injectors(truck would stop surging with the first 3 unplugged no change after install)(4th injector had a broken bolt)no change in idle,changed the fuel rail pressure sensor no luck I don’t have any codes that are fuel related could this be caused by a bad FPR ? I check the commended rail pressure and it’s fluctuating in sync with the rpm so is the actual rail pressure any feed back is greatly appreciated.
Pressure rail idle mid 4500psi jumping up and down between 4300-4700
