I'm pretty sure the garage door is 16x8. The overall size of the shop is 25x65.Nice shop, how wide is the door and the whole shop?
Wha kind of lift is that?I'm pretty sure the garage door is 16x8. The overall size of the shop is 25x65.
Here you go. There is 30 inches of space in between so I'd say yes on transmission pull.Wha kind of lift is that?
Does it have enough room to pull a transmission out between the posts?
I need to get up your way and do some roaming.
Looks like it to me as well.Ophir Pass?
Yup, Ophir pass. Amazing scenery.
There are a few that aren't suitable for full sized rigs, but most are doable with little issue.I plan on doing Ophir and a couple others this coming summer. Any issues with running a full-size?
Out of all the trails I've done with the wife , Ophir Pass is the only one that she absolutely will not do with me again. It's probably the most mild trail in the area but the loose shale/scree freaks her out.Yup, Ophir pass. Amazing scenery.
Like Wobly said, most trails are doable. I think there was only 2 or 3 switch backs that I had to make a 3 or 4 point turn on. Phaugipsy Gulch was pretty challenging, but worth the effort. The sound the shale rock makes under the weight of the truck is unnerving. One of the real challenges are the tourists in rental jeeps or side by sides, many do not follow any trail etiquette.I plan on doing Ophir and a couple others this coming summer. Any issues with running a full-size?
What part of the summer will you be going? I'll be out in mid to late July with some others.I plan on doing Ophir and a couple others this coming summer. Any issues with running a full-size?
Not quite sure yet, but probably around the same time.What part of the summer will you be going? I'll be out in mid to late July with some others.
