Hood Vibrating at highway speeds
KB RAM
Jun 3, 2019
San Diego
Has anyone else experienced this? My hood vibrates pretty violently when cruising at 75ish on highway. Dealer said it is normal with aluminum hood...
Has anyone successfully adjusted it to stop?
OuachitaAdventure
Jul 3, 2019
had a recall on my 2019 1500 for this. The puts some kind of filler in there so it wouldn't vibrate. May be something that's coming for the HDs also.
Jan 16, 2019
My 2011 HD does that as well. The front corners lift pretty good when it gets windy, maybe they need to change to two latches on the hood.
Ogamiitto
Jun 13, 2019
if that's true, then that's called a failure of design.
gregmachz
Apr 23, 2019
yes my 2019 hd does this too
this stuff is getting built cheaper every year
Gondul
Prince of Pintops
Mar 10, 2019
No issues here... my wife's Forester had a similar issue (also aluminum)... hood wasn't properly aligned and torqued down.
It was quickly fixed and haven't had an issue since.
Your dealer is being less than truthful...
DeVoTee
May 22, 2019
The Flutter a highway speeds are coming from the hinge mount. I've taken the emblems of the hood and you can see the flex from the aluminum hood where the hinges are mounted....... Design Flaw... needs bracing or a thicker piece of aluminum to mount the hinges. You can see the flex from just gently trying to close hood.
thestuarts
Jun 10, 2019
Yes, the hood on my 2019 3500 vibrates at highway speed. I thought something was wrong. I would love to know if someone finds a home remedy.
DeVoTee
May 22, 2019
My Dealers response was... "It operates how it was intended".
DESIGN FLAW!!!
ViperTower
Aug 2, 2019
My 2019 Dually does this. I thought I hadn't shut my hood all the way,. Hard to tell if it's shaking or flexing.
The HOFF
Don't Hassel me
May 8, 2019
Mine does too on my 2500. Have to see on 3500 next month.
Fierodough
Jun 28, 2019
Mine does this as well. It almost looks like the hood is trying to pop open. Like some play in the latch?
NordicNevs
Aug 29, 2019
I would bring it to the dealer but all evidence shows they are incompetent so I will look for the fix and likely DIY.
I don't even trust them to do an oil change properly. Sad state of affairs.
DeVoTee
May 22, 2019
I have removed the badging on the hood... The hinge bolts are behind the badging and you can see the aluminum hood flexing when you use pressure to close the the hood.
Design flaw for the light aluminum hood. The area around the hinge attachment needs reinforcement.
Please share if anyone finds a solution.
NordicNevs
Aug 29, 2019
Interesting. I wouldn’t expect the dealers to have anyone competent enough to repair this but I hope I’m wrong. Ram might surprise us.
bronco72
Aug 30, 2019
I have the same issue and did adjusted the stops it cut the vibrations down some but did not get rid of it.
