Heating Problems?
RhodeIslandShawn
Jan 29, 2021
I have 2014 Ram2500 Cummins and I’ve lost heat on the drivers side. I’ve read that this is common and want to know if anyone has had this same issue but was covered on the bumper to bumper extended warranty. Thank you in advance!
ctuck0659
Aug 28, 2022
Don't know about the warranty but my passenger heat didn't work nor would it blow air out the defrost vents. Dealer wanted $2000.00 to replace faulty actuators. I replaced one myself which turned out to not even be the problem. I'm convinced its a software problem that FCA doesn't have a fix for so I ended up disconnecting the pass. floor and defrost actuators from the system and wired them into 2 pole reverse-polarity rocker switches mounted in the little cubby hole beside the HVAC controls. Works perfectly.
Mikeyram
Feb 10, 2023
Very clever. Sometimes it pays to put common sense to work
