SmokeShowJoe
Excuse me Mr. Troverman... This all has been explained on this site before, the spongy pedal feel is all based upon several high-end computer programs that can and will save your life. Anti-lock brake system, Stability Control System. Add into the mix Adaptive cruise control with accident avoidance technology using front facing radar. All have to work and play well in conjunction with your braking system. Just the anti lock system itself on a dry flat road modulate each wheel of your truck over 50 times a SECONDS in a panic stop. Lets add in your ECM (Engine Control Module), TCM (Transmission Control Module), BCM (Body Control Module) And the Electronic Can bus system all work indirectly to make sure that you can be as safe as possible and stop in a emergency situation in the safest and shortest possible distance. So in closing, the engineers who designed all the systems to keep us safe at Ram I'm sure won't sleep well tonight knowing your very upset that your brake pedal is too spongy compared the out dated technology of your 17 year old 2005 F-350. But I will tell you that I will sleep well knowing that my 2021 Ram Cummings will out stop your 17 year old Ford @ 60mph by at least 3 truck length. And you can take that to the bank. Thank you sir for your time.
