Based on what I’ve seen only soot based regens shouldn’t be interrupted. If the regen is 24 hour based then there isn’t a need to run until complete. 24 hour based regens also haven’t taken 20 miles to complete in my experience, on average they are shorter than that.
Truck is using extra fuel with frequent regens. Fuel here in CA is close to $5 a gallon. When the truck goes into a regen, I need to drive an extra 20 miles or so for no other reason on the freeway because you shouldn’t stop the drive cycle during regen process. Waste of fuel, and time.
I have had 5 or 6 Ram HD trucks since 2017. Not once did I ever worry about regens....or interrupting regens, passive or otherwise. There seems to be a lot of speculation on this forum as to the conditions and what triggers a regen. No where in the 0wners manual does it say to never interrupt a drive cycle during regen, it does say the emissions mode can last for 20 minutes of drive time but does not say that must be continuous. I think even the grocery getters can do 20 min straight of drive time daily.
I daily drive about 30 miles a day during the week and then on weekends as well. I tow our 5th wheel maybe 4-5 timers a year. These trucks will let you know if something is truly wrong - the engineers did not slack on warning messages and chimes on these trucks. They also engineered them to be driven as daily/weekend warriors or as the the Hotshot guy hauling everyday.
You can nerd out on regens and tracking the cycles but the Engineers did that already. Just drive the truck...sometimes I think people over think this stuff and create issues that are not there.
"If the engine is allowed to idle or the truck is driven
on low engine speed drive cycles for more than two
hours, the system will automatically enter an emissions
operating mode that will increase the engine idle speed
to 900 RPM. While in this mode, which is designed to
help maintain the Diesel Particulate Filter, the engine
idle speed will return to normal when the brake pedal
is applied. A small change in engine tone or a slight
change in engine performance while accelerating may
also be noticeable at speeds below 20 mph (32 km/h).
This operating mode may last for up to an hour of idle
time, or around 20 minutes of driving time."
Exhaust Filter Nearing Full Safely Drive at Highway
Speeds to Clear — When the Diesel Particulate
Filter (DPF) is 40% full of particulate matter, the
vehicle will look for opportunities to automatically
enter regeneration mode, without alerting the
driver or requiring any action. However, under
conditions of exclusive short duration and low speed
driving cycles, your Cummins® diesel engine and
exhaust after-treatment system may never reach
the conditions required to remove the trapped
Particulate Matter (PM). If this occurs, and the
DPF reaches 70% full, the message “Exhaust Filter
Nearing Full Safely Drive at Highway Speeds to
Clear” will display at key-on and when the vehicle is
in PARK. If your vehicle has an instrument cluster
with analog gauges it will display the words "at
Consistent Speed" instead of "at Highway Speeds".
Either message will be accompanied by a single
chime.
Although it is not necessary to immediately drive
at highway speeds to address this, or to continue
driving once regeneration has started, it should
not be neglected for long. The fuller the DPF is,
the longer the regeneration process will take to
complete.
For example, if the DPF reaches 90%
full, complete regeneration will typically require 45
minutes of driving to restore the system to normal
operating condition.
● Exhaust Regeneration In Process Continue Driving
— If the DPF reaches 70% full, this message will
display with a chime when the regeneration mode
is automatically engaged while the vehicle is being
driven at a suitable speed. This will repeat every
three minutes while the DPF is self-cleaning, until
the particulate level is reduced to zero.
If time or
circumstances do not allow the vehicle to continue
to be driven, the system will resume regeneration at
its next opportunity and will redisplay this message.
● Exhaust System — Regeneration Completed — This
message indicates that the DPF self-cleaning is
completed. If this message is displayed, you will hear
one chime to assist in alerting you of this condition.
Exhaust Filter Full — Power Reduced See Dealer —
This message displays if the DPF reaches 100%
full. It will be accompanied by the Malfunction
Indicator Light (MIL) and a chime. Engine power
will be reduced. At this point, regeneration is no
longer possible and the vehicle should be taken to
an authorized dealer as soon as possible to have
the DPF manually cleaned. In extreme cases, a
completely full DPF can damage the exhaust system,
requiring part replacements. For these reasons,
never let the DPF reach 100% full.
NOTE:
The DPF gauge on the Premium Instrument Cluster
remains available during DPF regeneration. Analog
Instrument Clusters will display "Automatic Exhaust
Regeneration In Progress" in place of a value.
NOTE:
Failing to follow the oil change indicator, changing
your oil and resetting the oil change indicator by 0
miles remaining will prevent the diesel exhaust filter
from performing its cleaning routine. This will shortly
result in a Malfunction Indicator Light (MIL) and
reduced engine power. Only an authorized dealer will
be able to correct this condition.
