DisneyDarwin1
I have the Mopar camera and kit with proprietary plug installed on my fifth wheel. It works initially when I plug it into the bumper port, but usually fails sometime during each drive. Fiddling or resseating the plug will fix it, only to eventually fail again. The problem is definitely with the plug and port, so what can I do to fix it. Should the pins in the receiver be narrower or farther apart? The fit seems good, but I could attempt to make plug fit more tightly in the port. I’d bypass the plug and port entirely, but when I unscrew the proprietary plug, I’m left with a strange inverted female RG58 connector, very atypical. Suggestions welcome. Pictures attached of plug and receiver (before I cleaned them).
