Changed ATF - DPF clogged throwing dealer error
nosurefireway
2020 3500 68k - changed ATF, second maintenance (36k last time). Used same 3309 Mobil ATF I used last time. Less than a mile after I replaced fluid and my DPF is fully (100%) clogged. Now I’m no rocket scientist, but this can’t be random right? Causation and correlation seem obvious. How could ATF end up in the exhaust? Transmission cooler leak into coolant and coolant leak into head and then into exhaust? Is that even possible?
There’s no way the two are connected. Has to be a purely random coincidence. Unless you accidentally damaged or disconnected a harness for the emissions system in the process of completing the fluid service.
I agree! Simple fluid replace. I replaced the filter during the first service. This was just a drain plug dump and a screened (filtered) funnel pour. Nothing else touched. But it just seems very odd it was the first mile after the maintenance!
Have you changed any other fluids or filters recently? At 68k you’re nearing the time where the CCV filter should be changed. Normal service interval is 75k for that, but they can be saturated sooner and that can sometimes cause regeneration issues. Any other active codes in the system? I’m assuming you’re seeing code P242F for ash accumulation in the DPF?
Oil about 2k ago. No other codes or errors popped up. Didn’t run the codes because I’m on the road traveling; went right to the dealer (I’ve got extended warranty, or at least I paid for one).
Sorry to keep asking questions but:
When was the last time you changed your engine air filter?
When was the last time you changed fuel filters?
Have you been monitoring how often your truck goes into automatic regeneration?
Do you allow the automatic regeneration cycles to finish before parking the truck?
Ask away! Happy to answer!
Both fuel, air, cabin and oil filters changed with oil 2k ago. I haven’t noticed the regen recently, but it usually is quick. I try and run the truck until it finishes.
Funny you mention this - my truck just gave me the service exhaust system see dealer message this AM - I just replaced the fluid in my trans about 1k miles ago too.
I know the two are entirely unrelated but I found this thread on my way to the frequent regen one.
Pull that out and toss it in the trash.
Get a legit Mopar 53034051AB or a Fleetguard AF27684 from Geno’s Garage and try it out. In the meantime, with that P242F, it’s not an easy code to clear because the truck things the DPF is full of ash and it won’t let active regeneration run. You might have to have someone with a scan tool check DPF pressures and see if it’s actually full. They’ll have to reset the trucks regenerative filter timers to trick the truck into thinking it got a new DPF put in, then run a parked regen and see what happens.
Probably either a sensor issue in the emissions, or a fuel related issue.
Yeah I hear you. I will replace the air filter when I get it back. It’s currently kicking the techs’ butt in the dealer garage bay. Apparently it isn’t happy and has thrown a few more codes. Not looking good for my pending trip…
Did you get your issue fixed?
Ugh. That doesn’t sound good. Hopefully they’re up to the challenge.
To be clear this wasn’t the CCV, just the air box; I haven’t replaced the CCV filter yet. That was on the short list for today until this happened.
Yea some years of these trucks are way too picky to be running a stp air filter. That was the joke of ol Homer Simpson. Stick to oem if you have one of the troubled years of the 4.5 gens
Ya my guess is sensor issue in the emissions system. I dont want to detract from this thread, just found it coincidental that I saw this as I was coming to post in the frequent regen thread.
Nope. Code just popped this morning and the soonest i could get into the dealer was next Wednesday So I’ll know more then.
UPDATE: using the none-mopar filters has me out of warranty now! :( Shame 'Ram' doesn't warn customer they will void the warranty if you don't use their filters... Almost like this is a great excuse to slide out of contractual obligations on poop emissions equipment. I swear they, the dealer, said you're good so long as you don't replace parts with non-OEM. Either way, the dealer cleared the codes, and said I had 11 grams of soot in the system; that I would need a whole new DPF and sensors ($4K+). Long story short, I needed the truck and drove off the lot without the repairs. Around 60 miles later and a 45 minute plus regen, the truck cleared the codes and apparently burned off the 11g of soot. No more issue. Looks like I will be figuring out some aftermarket solutions to resolve this issues permanently. Thank you for all the comments here.
