CAT Scale Weigh-in Heavier Than Curb Weight?
Herrred
Apr 29, 2021
My 2021 2500 Laramie CCSB has a curb weight of 7,989, with a payload of 2011. Did a CAT scale today and she's showing heavy. I filled the 31g tank and had my wife and I in the cab, me at 210 and her at 110. Only after market addition so far is a tonneau cover. How am I at 8,500? Anyone else showing heavy on the scales? My payload is down to 1,500 and not too thrilled about it.
Jimmy07
Re-coding from an easy-chair
Apr 5, 2020
Because the curb weight is the weight of the vehicle as built, without you, the wife, or a tonneau cover.
jadmt
Aug 29, 2020
Age
65
Missoula
When I weigh mine I get out of the truck. everything adds up. I like to say I weigh 200 lbs but realistically when I step on the scale the dang thing tells me dressed and ready to go I am 230 :) and no way will my wife let me see what she really weighs :).
DevilDodge
Nov 21, 2018
Age
46
Central Pennsylvania
8500 minus 210 and 110 is 8180lbs.
8180 minus 7989 is 191lbs. So I am guessing you had other stuff in the truck or you have a really heavy bed cover. Or your bathroom scale is off.
Also the scale has a +/- 40 lbs per pad. So it could technically be + 40 on each...which would be 80 over
8500 sounds right to me
Herrred
Apr 29, 2021
I have a few things in the storage area under the back seat, a few tools, tow ropes, ratchet straps, I guess that could add up to 80 or so. Thanks for the guidance.
Herrred
Apr 29, 2021
Exactly. Payload disappears quickly when you actually start doing the math.
No kidding....really didn't want to go 3500 as the 2500 rides better as a daily driver. I will have to make some adjustments in my auxiliary tank and TT plans.
Chris.Gio
Jan 24, 2021
Ignore. 10k made up. 6k an axle is real. Lose my number if you get pulled over ;)
gimmie11s
Mar 30, 2021
Hit the nail on the head. The axles, frame, motor/trans combo on your truck is MORE than capable. It's the "soft" suspension that makes up the bulk of the difference between the 2 trucks.
My 2016 2500 with rear coils was not very confidence inspiring pulling our 14k loaded 5th wheel. Had plenty of power and stopped fine, but the softer suspension really makes you feel the weight of the load youre pulling once youre over, say, 10k lbs.
ClawSS
Jan 31, 2020
Lexington, KY
‘22 Mega Hemi - weighed today actually
8200lbs; 4600/3600
Full tank + me & wife + all that in my signature (and 37” spare in the bed)
cj8rockcrawler
Dec 11, 2021
For reference, here's my 22 megacab CTD.
Nov 15, 2022
Cat Scales are in 20# increments
My 2022 2500 crew cab gasser 8 foot box
DevilDodge
Nov 21, 2018
Age
46
Yes. 20 lb increments.
Error allowance is ±/- 40 lbs per pad. Which is what I mentioned in the quoted Post. But now I can not find where I found that...I have hundreds of posts about CAT scale tickets.Screenshot_20200526-084249_2.png
DevilDodge
Nov 21, 2018
Age
46
The variance of our scales is established in the National Institute of Standards and Technology Handbook 44 Table 6. Class IIIL scales are allowed one division, or a 20 pound variance off zero for each 10,000 pounds of weight applied.
Most calibration tests preformed by either the State Weights and Measures or a licensed scale service company will use a minimum of 20,000 of certified test weights. In the case of a 20,000 pound test, anything beyond a 40 pound error in reading would be a failed test."
Maybe I combined the reading of something. This was all I could find. Lol. But I originally got the info from a friend who tows travel trailers for a living.
ClawSS
Jan 31, 2020
Lexington, KY
Cool how I got rounded to 00's. Makes my OCD happy and my inner conspiracy theorist think the scales are wrong because.....gov-mint.
