Another update:
Daughter had a soccer tournament 4 hours away this past weekend. On the trip out, everything worked fine, had the vent blowing on 2, and the temp set about 4 notches up from full cold just to circulate some air. Sunday was rainy and cold so the wife adjusted the temperature to 3/4 warm. At that point, the temp blend door went to full hot and stayed. It would not go to cool even after the truck was shut off. I had taken my OBD dongle, so before we left to head home I attempted another blend door actuator calibration in the parking lot, but I received an error message that "No data was received from the ECU /interface or data was corrupted". I drove 4 hours home manually cycling the defrost on and off every 10 minutes or so just to keep the windows clear (still hot).
Today I again attempted to calibrate the actuators and received the same error message. I also tried several other selections under the HVAC ECU and received the same error each time. I pulled the glove box out and the front passenger carpet back so I could visually see the blend door. This time it worked as it should during testing. I moved the temperature controls through the range and recorded gauge readings via AlfaOBD. It's to me that I can connect but not perform any tests. It's also odd that even though the gauge shows the target % movement correctly, it shows the actual % movement as zero even though I could visually verify the motor and linkage was moving.
I was able to read HVAC ECU codes and have a B11CB - Blend door binding/faulty as well as U0422 - communication error.
I feel like my next step is to replace the blend door actuator. It's easy to see but looks like a PITA to change unless I can figure out a way to easily remove the passenger footwell vent duct that runs along the bottom of the glove box. There are two bolts that I can remove but the duct still doesn't want to come out.
Any thoughts are welcome.
@Jimmy07 can you possibly shed any light on the communication error?
View attachment 50677View attachment 50678View attachment 50679
