BAK Tonneau Covers w/ RAMBox
huff2462
May 12, 2019
Severn, MD
I ordered a 2019 RAM 2500 with RAMBoxes. I noticed on BAK's website, it has the following notice:
"NOTE: When ordering the RamBox part numbers, the RamBox rails need to be the OEM factory silver cargo rails, not black, to function properly with our covers"
I ordered my 2500 WITHOUT the $295 RAMBox Utility Group (AM8)... Does that mean I won't be able to use the BAK Tonneau Cover or do the silver cargo rails come on every truck?
Gondul
Prince of Pintops
Mar 10, 2019
If you do not have the RAMBox there is no cargo rail on the 2500.
huff2462
May 12, 2019
Severn, MD
No, I have the RAMBoxes... But I didn't order the Utility Group (which I think includes the rails and tiedowns). So I'm wondering if I'll have the silver rails BAK is referring to.
I guess I could just wait until it's delivered in the next week or two... But I was hoping to order it ahead of time.
boom3198
Jun 3, 2019
NE Ohio
The rails they are referring to are the bright silver aluminum rails at the top of each bedside that the adjustable tiedowns go into. BAK uses pieces of aluminum angle in those slots for the tonneau to latch to and the seals sit on top of those rails. Ill post a stock photo in a min.
boom3198
Jun 3, 2019
NE Ohio
405 406
Black Rails Silver Rails
The difference is the top of the rails. The silver ones are extruded with different size channels in them and the top of the rail is not nearly as wide. the black ones will not allow the cover to fit between the rails.
redwinelvr
Mar 5, 2019
So how do we know if we are getting the black rail or the silver rails? I've also got Rambox, Rambox Utility group, and bed utility group on order.
btshep
Aug 20, 2019
you get the black rails if you order the factory tonneau cover with your truck. my 2016 came with the black rails so when I decided to change to backflip f1 cause I wanted a hard cover I had to order the silver rails from my parts department and replace the black rails added hundreds to the swap
ERK
Jun 10, 2019
My '19 2500 came with the soft tonneau cover and the "black rails". I am trying to order some of the regular "silver rails" so that I can install my aftermarket cover. Does anyone know if the rails from the '18 2500 will fit? None of the online sites (including mopar store) list parts for '19 2500's yet.
Here are the parts i find for the '18 2500:
Right
Left
Thanks,
