Just noticed this thread, and even though I explained it in your PM, I’ll post the response here so others will know why they do need to use AlfaOBD for this swap:
The 2019+ rams are less picky about LEDs but, there’s something going on that you probably would never notice. Right now, with your new LED tails, when you apply the brakes AND use a turn signal, they are flashing red-amber-red-amber. This is because the brake lamp and turn signal LEDs are on the same board, and the brake lamp isn’t dropping out for the turn signal. The proper behavior when the brakes are applied and turn signal on is amber-off-amber-off.
So, you at least need to use AlfaOBD to change CBC Config I/O Usage: Separated Lighting Brake Lamp Dropout to yes. Since you have to do that, you might as well change the rear lighting settings to LED.
Hopefully this image shows up correctly. It shows the improper operation of the brake light staying on with the turn signal:
