Have pics and angles of those +1 vectors?I just bought Fuel Vectors 18x9 with 1mm offset does anyone have pictures of what they look like?
Tires are 35x12.5x18 (make sure you get load range F) and the truck has a 2.3” Bilstine front coils and shocks. I’ll get another picture today.Looks good! You don’t happen to have a front end pic in a distance? Tire specs? Lift?
Any rubbing or trimming with those 2.3” ?Tires are 35x12.5x18 (make sure you get load range F) and the truck has a 2.3” Bilstine front coils and shocks. I’ll get another picture today.
No rubbing or trimming was required this is the leveling kit I used https://www.bilsteinlifts.com/shop/...ar-lift-shocks-2019-2020-ram-2500-4wd-diesel/Any rubbing or trimming with those 2.3” ?
Forgot to mention 3500 with a diesel in itAnyone able to help me with this question as I have no clue on rims.
I have a set of MT legend 35x12-5x20 sitting in the garage waiting on truck arrival.
Will these rims work? Do the tire pressure sensors transfer over or do I need to order something else?
Fuel Off-Road D77520008247 Fuel Off-Road Typhoon D775 Series Matte Black Wheels | Summit Racing
Free Shipping - Fuel Off-Road Typhoon D775 Series Matte Black Wheels with qualifying orders of $109. Shop Wheels at Summit Racing.www.summitracing.com
Thanks in advance
ReplyAnyone able to help me with this question as I have no clue on rims.
Thanks in advance
Backspacing is, as you described, from the back of the wheel to the mount face.I realize this is an older thread but I'm trying to get my head wrapped around wheel sizing. In my hotrod days we would measure backspacing from the back of rim to the mounting surface. When you see a number such as +18 does that mean the outer edge of the wheel will be farther away from the axle or closer than zero? will a + or - number move the wheel/tire outboard? Can anyone tell me what a stock 18x9 wheels spec would be? Probably a dumb question, but I don't know, thanks.
Thank you, that's helpful.Backspacing is, as you described, from the back of the wheel to the mount face.
Offset is +/- from the center of the wheel. Negative moves the wheel out (mount face moves in) positive moves the wheel in (mount face moves out)
If the wheel is 8” wide with 0 offset the mount face is centered in the barrel of the wheel. That same wheel would measure 4” of backspace since 4” is half of 8”. Sometimes it’s not exact because they round. If the same wheel was available in +12 that’s roughly 1/2” inward (mount face moved out) so it would have 4.5” backspace now.
Clear as mud, right? Good. Lol
