4500 vs 5500
milty
Dec 12, 2022
Hey I'm new here. I'm looking to upgrade my truck and will be hauling a double deck 40 ft livestock trailer most of the time. Is the 5500 worth it or should I go with the 4500, thanks.
What’s the max pin weight?
What gears are you considering?
A 3500 C&C with 4.10’s has a higher GCWR than a 4500 C&C with 4.10’s, but a lower payload.
A 4500 C&C with 4.44’s has a higher GCWR than a 5500 C&C with 4.44’s, but a lower payload.
Peak towing for the C&C trucks is the 5500 with 4.89’s.
milty
Dec 12, 2022
I don't know the max pin weight but I do know it'll be maxed out occasionally... as for gears I was considering 4.44 but I'm not sure as half the time I'm going thru central Illinois and the other half thru southern Ohio and west Virginia and I've never driven with anything higher than 4.10
UglyViking
Jul 11, 2020
Similar to what @AH64ID mentioned, the biggest thing you'll want to consider is how much pin weight you need at max, and probably go a hair over for the extras that you're surely to add/want. Also consider things like extended fuel tanks, additional spare tires, tie down or recovery equipment, etc. Start with max of what you'll tow then work backwards would be the best recommendation. Even though you're already looking at 4500+ trucks that's the biggest mistake that guys make with these trucks, too many guys get a 2500 when they need a 3500, and so on.
What’s the GVWR of the trailer?
Great White North Eh
Squish Cat - And So
Nov 10, 2019
Double deck 40 without a hi-way tractor? Unless it’s a pig/ sheep hauler I don’t know if that’s possible. More trailer info will get a better internet answer.
milty
Dec 12, 2022
It's not my trailer so I'm not sure of some of the specs off-hand which is kinda dumb to be honest but I'll find out and let you guys know.
