'21 3500 Rear Air Suspension - Smoooth Ride!
Nick
Mar 14, 2020
I read the PDF . They say 3500 but they are talking front and rear . Probably used on a 2500 also . It is simple enough to do . Basically just changing the angle of the sensor arm one way to lift and the other way to lower . Post how it worked out for you .
Dunn08
Aug 6, 2021
I have a set installed, and you can set them a bit shorter than the stock arms, which resulted in my bags feeling completely empty.
2022 Flame Red Night Edition DRW Laramie 3500.
H/O w/ Aisin. Carli Lift, Thuren Steering. TIS Off-road 544BM Wheels w/ Ridge Grapplers.
Nick
Mar 14, 2020
W Laramie 3500.
How was the ride and will they fill to the proper alt ride height level when hooked to a trailer ?
Dunn08
Aug 6, 2021
I planned on hooking to my 42ft toy hauler this weekend to test that out and play with it a little. Unfortunately I won’t get it back from getting PPF and ceramic coated until next week sometime.
I will definitely hook up next weekend and report back with pics and info.
I need more seat time before I report on ride quality. I haven’t driven it since I picked it up, until yesterday to the alignment shop and today to the detailer. Want that film on the front before I start driving to work and get rocks thrown at me.
CdnHO
Nov 17, 2020
Ontario
Have you tried "alternate ride height" after you hook up? On my truck, ARH drops the rear by almost exactly 1.5" vs standard height.
Yes. Using alternate ride height. Still trailer is nose high.
CdnHO
Nov 17, 2020
Ontario
Installed a set on mine. Unloaded no change due to leaf springs. When I select alternate trailer height I get “selected height not allowed due to payload “. Will know more when I tow fifth wheel. I did have to shorten the rods since they were as long as the OEM rods at the shortest length. No big deal. Cut off about 3/4 inch so they are now adjusted to 3/4 inch shorter than stock rods. Easy install. Be sure to press firmly to seat the ball. Popping over the weather seal my lead you to think the thing is installed but a firm press is needed to actually seat the ball into the socket. The photo actually shows the links installed INCORRECTLY. They were not installed in the socket even though it felt like it. They were just slipped over the weather seals and required additional pressure to seat them in the sockets.24BD45E0-A3B1-461F-AA79-697E350529BE.jpeg
Dunn08
Aug 6, 2021
That’s interesting, mine can be set about a 1/2” shorter than stock before they bottom out. With that being said, when I get my truck back I’m going to cut a little off as well. With your arms angled down, I assume your bags are pretty empty. You can try bed lowering mode to see if you drop anymore. Mine didn’t.
CdnHO
Nov 17, 2020
Ontario
Not likely that bed lowering will do anything although it did drop about 3/4 in with alternate trailer height. But after the error message, it went right back up. Not enough weight in the bed probably.
John Jensen
Feb 11, 2020
I've read it takes 600lbs to operate. Mine drops 1 1/4" with my 1200lb hitch weight
Nick
Mar 14, 2020
Installed a set on mine. Unloaded no change due to leaf springs. When I select alternate trailer height I get “selected height not allowed due to payload “. Will know more when I tow fifth wheel. I did have to shorten the rods since they were as long as the OEM rods at the shortest length. No big deal. Cut off about 3/4 inch so they are now adjusted to 3/4 inch shorter than stock rods. Easy install.View attachment 27333
It will say that if you do not have a load on the truck . They look good . Basically a turn buckle setup
Nick
Mar 14, 2020
You may have to come up with some suspension mods to get your fiver up. Had to do a couple of things on mine to get it higher . It is only 14 k loaded yours would be more or a challenge .
CdnHO
Nov 17, 2020
Ontario
Would be pretty difficult to modify this trailer suspension. Has the MorRyde equalizers. The springs are only connected at one end with a slipper arrangement at the equalizer end. Only way would be to extend the hanger plates which would entail some major surgery. Hopefully the adjustable links will bring the nose down to a point that is acceptable. I doubt I will be able to get it perfectly level; however any improvement is a good thing.
Cpschevy
May 16, 2020
Idaho
Their instructions are confusing at best. I cannot find instructions that specifically address 3500 trucks with air suspensions. I bought a pair to lower my rear end an inch or two to give me a more level fifth wheel trailer. I have not installed them yet so hoping it works. They are however rediculously priced for what they are. But they are the only option I could find.
You will have to cut a little bit of the threaded rod off to shorten the links enough to take all the air out of the bags because they are same length as factory totally closed up. I did this and got about 3/4" drop but that is it , Would have to raise the front end of the truck 3/4" if i wanted it totally level.
CdnHO
Nov 17, 2020
Ontario
At bottom out, mine were maybe an 1/8 inch shorter.
CdnHO
Nov 17, 2020
Ontario
My links are about 3/4 inch shorter than factory after cutting the threaded rod. The rear drops by 1/2 inch when set to "bed lowering mode" but goes up again when "bed lowering" mode is turned off. Leads me to believe that there is normally a certain amount of residual pressure in the bags; probably to protect them. "Bed lowering" also turns off when starting to move at I think 5 mph. Would love to see the technical info on the system. Just guessing at this point how it all works.
love2build
Jun 22, 2021
My 22 is in for some minor issues. I did inquire about the difference in bag pressure from side to side as my drivers is a bit more inflated than passenger. I was told that due to fuel tank and driver weight etc that the drivers bag would always be as it is. I admit it makes some sense to me however I would like to see how the truck rides without air at all in the bags and will adjust myself later on like indicated earlier in this thread. At this time I’m not interested in the links as my truck sits fine as it is.
John Jensen
Feb 11, 2020
Your dealer is correct, however, from the factory my truck was over compensating.
My 2020 driver side sat 1 1/2" higher than the passenger side and the driver side had more air (harder) I adjusted the driver side bracket and now the driver side, with 50 gal fuel tank half full and driver seat empty, sits 3/4" higher and both bags feel about the same. I'm satisfied.
I might add that the bracket bolt holes were not elongated as was mentioned above. Both were round and a bit oversized, allowing for a very small amount of adjustment. If I need more adjustment, I would have to buy the aftermarket adjustable inks
Linked4door
Aug 26, 2020
Installed a set on mine. Unloaded no change due to leaf springs. When I select alternate trailer height I get “selected height not allowed due to payload “. Will know more when I tow fifth wheel. I did have to shorten the rods since they were as long as the OEM rods at the shortest length. No big deal. Cut off about 3/4 inch so they are now adjusted to 3/4 inch shorter than stock rods. Easy install. Be sure to press firmly to seat the ball. Popping over the weather seal my lead you to think the thing is installed but a firm press is needed to actually seat the ball into the socket.View attachment 27333
Either of you guys have a eye to eye measurement of the stock rods? Or the length or the rod after it was cut? I just got my adjustable links and want to cut them down if needed before I fly down to pick up my truck tomorrow. Want to cut off the least amount possible.
