2023 limited, rambox W/ 5th wheel prep
pr3dict
Jun 9, 2022
I have 5th wheel prep w/ no rambox delete line item on my build that is now schedule D but I'm afraid it's not going to actually be built.
Can someone please ask their dealer to find out from corporate if this is possible and will be built? My dealer has reached out to their RAM rep a week ago and still has not received an answer back...
They dont want to cancel the order because they think it will be built and I dont want to press the issue because I am fine with having both if they've figured out a new way to do that on the 2023's. But if they cant then I will press the issue.
Thanks anyone that can help.
Why does your dealer not call the rep again if anyone else calls they wont get any info without an order number for them to look up…
darrellr
May 24, 2022
I don't believe a Rambox bed would allow enough room for a fifth wheel pin box to rotate around without hitting the sides of the box. I would think a gooseneck is probably ok, but not a fifth wheel.
pr3dict
Jun 9, 2022
This was an initial concern of mine but I found that if I light enough money on fire I can acquire a sidewinder pinbox that pivots higher up and clears the bed.
Depends greatly on the pin box but lots should fit or use a turning point hitch
pr3dict
Jun 9, 2022
Finally got word from RAM rep.... They said even though the line item for RAMBOX Delete is not there, the truck WILL NOT be built with a rambox.
Case closed!
