2021 2500 68RFE slipping on shift??
Ram911
Sep 25, 2021
I seem to get some slipping just before shifting gears. I believe its more noticeable on 3rd or 4th gear. The RPMs move up about 2 lines on the tach and you can feel the slip. It does shift in smooth after but just doesnt seem right and will probably cause wear.
I have read some threads on this and some say normal and some say its an issue. Anyone experience this?
Edited: to add the truck has 2800 miles on it
thanks
There's a shift "flare" because the TC is unlocking between shifts then locking again.
I think what you're experiencing isn't a slip before shift, but rather an unlocked shift up, then TC lockup. If you're watching the gear display, it lags.
Ram911
Sep 25, 2021
Are you saying this is normal and nothing to worry about?
What you explain sounds like what I am experiencing. I just never had this happen in any other Truck/car I have owned or never noticed it.
Thank You
Thank You
When you get in to HD vehicles you cant compare them to “any other Truck/Car” Your trans is shifting perfectly as designed it unlocks the TC then shifts then relocks the TC
MtnRider
Feb 5, 2020
Georgia
Thank You
It's normal for that truck/transmission combo....
Ram911
Sep 25, 2021
Thank You for the valid info. I found this in the manual which explains what I noticed.
TORQUE CONVERTER CLUTCH​
A feature designed to improve fuel economy has been included in the automatic transmission on your vehicle. A clutch within the torque converter engages automatically at calibrated speeds. This may result in a slightly different feeling or response during normal operation in the upper gears. When the vehicle speed drops or during some accelerations, the clutch automatically disengages.
That's the "lockup."
All modern autos have a lockup TC, it's just felt more in your RAM. There may be some torque management contributing to that as well. I know on the Aisin the torque management (reduction) is significant during shifts to protect the trans.
Desertfox73
Aug 19, 2021
This thread just made my day - I've been feeling the same thing, and wondering if it's normal.
I love what I learn on this forum. Thank y'all.
dhall5483
Jun 15, 2022
I just got my 2021 2500 and with the same mileage is feeling the same thing with the transmission so I assume it the same thing?
