Yeah that's because dealers can't update that setting with their software any more. You can do it with one of the 3rd party tools.
I looked at them, but considering they only support 2017 and older vehicles and only run on Windows and Android platforms, made me think they were a dated product that is not being actively updated or supported.For that kind of money for a dedicated single use tool, why wouldn't you just get setup with AlfaOBD?
Another concern for me was the fact there is no physical address or phone number to contact them listed anywhere on their very dated looking website.
I prefer to support legitimate US based businesses. As stated in my original post, the product I used came with great support that was only a phone call away, even on a Saturday. Good luck with that with the AlfaOBD product.
This is the one both JC and I used. https://www.roughcountry.com/speedometer-calibrator-90019.html It works and the company is great to deal with. But there are a few little things to be aware of, the first is why I know first hand they are great to deal with.
When connecting up the power/USB cable, make sure you use the USB port in the center console, not either of the 2 on the lower dash below the touchscreen. The ones below the touchscreen have both data and power, which is what you want for connecting a phone for Apple Car Play, but not for the programmer. When using the data USB ports on the lower dash the programmer just sits there communicating with the truck and never moves to the calibration prompts. Using the center console, power only USB, allows the programmer to work correctly.
The other thing to be aware of is the cable you need to connect up under the dash to get around the new security on the OBDII connector is a little challenging to get in. Due to the location and fitting a hand up in there. The connector slides right in and back out easily, but can be a bear to reach to do so.
Lastly, their website states in the title for the programmer it works on our year and model, 2500, of truck, but in the fitment section further down it says it only works on 1500. It does work on the 2500 and they will confirm this if you speak with them.
I used AlfaOBD two weeks ago to change TPMS thresholds and tire sizes on my 2020 Power Wagon. I ran into a small problem with a newer Windows version and support was stellar. I got a fixed version a fee hours after writing them an email.
Why would you say they only support 2017 and older? AlfaOBD is continuously supported and frequently updated. There are several heavy users that have direct access to the developer. Do you have after hours telephone support for any app on a mobile platform?
Do you think the bulk of that RC product isn't Chicom sourced? I'm all for supporting US manufacturing, but be realistic.
I actually took my rig to AEV so they could try it. they had not actually had a 2020 pw to try in person so they wanted to run some tests. Worked great on mine. The person who invented the pro cal was the one who was running the tests and my guess it won't be long and the issue will be fixed. It was not with the transmission but a communications programming issue.AEV told me that they stopped selling the unit for the Power Wagon stating that there was a problem with the calibration with the transmission. I too used the RoughCountry one with my 2020 Power Wagon and it worked just fine.
Sent from my iPad using Tapatalk Pro
Oh that’s great! Thanks for the inside scoop. Any benefit over the RoughCountry?
yes but only certain amounts. the following is from the snap instructions.I believe the AEV unit also allows you to set the TPMS warning light threshold.
