DeepH20Driller
Start your own thread....such as "2022 VIN#'s and Order info".
I second that. I’ll join.
I would do it but, honestly I am a "tech dunce" and will leave it to someone that knows what they are doing.I second that. I’ll join.
Here's the sheet: https://docs.google.com/spreadsheet...jqFtyJfuADQC5i5D7fX4lQqrQ/edit#gid=1884861679Can you share it? If not, I'd be happy to setup a spreadsheet + form. Could collect username, date ordered, trim level, last 8 of VIN?
I'll start that in a bit to raise the level of awareness.Start your own thread....such as "2022 VIN#'s and Order info".
Adding option build codes from our build sheets may be super helpful. Need to think about the best way to structure the spreadsheet to allow you to sort by them effectively or build pivot tables. Owners would have to fill in their respective data from the build sheet.I'll start that in a bit to raise the level of awareness.
I may also go back through some of this thread to enrich some of the VINs I already noted to try to add some model and trim details to the sheet. Maybe there are some other interesting analytics/summaries I could put together.
Delred night edition?Order the same from aaron
Very nice!Here's the sheet: https://docs.google.com/spreadsheet...jqFtyJfuADQC5i5D7fX4lQqrQ/edit#gid=1884861679
I also put together a form which is linked at the top. I haven't wired the two together yet, but I'll find a way to combine them.
I also put this in my signature.
You can request that members post a copy of their POC to including the vin and order date. Some people redact that info.I'll start that in a bit to raise the level of awareness.
No limted 3500 ho dieselDelred night edition?
I ordered mine on the same day. Laramie 2500 vin NG103632My order was submitted on Memorial day
3500 mega HO SRW Laramie NG103654
Wonder if it would make sense to denote what motor everyone has. That might be a big factor in when things get produced.Here's the sheet: https://docs.google.com/spreadsheet...jqFtyJfuADQC5i5D7fX4lQqrQ/edit#gid=1884861679
If folks aren't comfortable sharing the full VIN, I don't want to pressure them.You can request that members post a copy of their POC to including the vin and order date. Some people redact that info.
I added a few optional fields to the form if people want to include that information. I also created a new thread where we can continue to talk about what to do with the form and data: https://hdrams.com/forum/index.php?threads/2022-hd-crowdsourced-vin-order-tracking.6189/Wonder if it would make sense to denote what motor everyone has. That might be a big factor in when things get produced.
