One of the best looking rides I have seen!Wheels and Suspension Ceramic Coated today. Now the entire truck is done. The sunset is bouncing off her in the 117 degrees weather here in AZ.
View attachment 17892View attachment 17893View attachment 17894
Thank youOne of the best looking rides I have seen!
Ordered a set of flaps. Hopefully no issues this time around.I believe that may have been my problem. Did your flaps fit good with the spats? I’ll check my records and see if that was the flaps I bought. I did get them from BAM and when I returned them I thought they were gonna kick back on me as they responded to me and stated these were not for the Mopar flares. I’ll validate the numbers. Thanks
Camped and woke up to this
Nobody said anything about this yet?Completed installing the cabin temp sensor using a custom harness I made. Also installed the proper sun load sensor and auto HVAC bezel. I now have fully working auto HVAC.
I was only able to get the dual zone bezel working by leaving the HVAC configuration set to dual zone. If I tried setting it to single zone ATC, it would get stuck on defrost and heat. The touchscreen and manual buttons would get disabled. But setting it to dual zone ATC works with both zones set to sync and setting it to Auto. The bonus is the dual zone Bezel has better lighting on the dials and buttons.
I did not take pics but this procedure is fairly well documented.
Deets!?
Deets!?
You're going to love those tires, especially in rain or snow.all clean with the new Falken Wildpeak A/T3W LT285/65R20
