You have to pop off the convex mirror, then there is a TX15 screw holding the marker light in.
You have to pop you’re concave mirror off. And then there’s a T? Bolt holding it in. I just removed mine and painted. There’s a YouTube video out there. I’ll try and find. The concave mirror just pops off. Adjust your flat mirror where you can get your fingers behind the other.
Thank you both for your prompt responses. It sounds easy enough. Can't wait to get it done.
Well......I drove it home from the dealership......325 miles to be exact. Graduated from the 2500 to the grown-up.
Washed installed step rails on Sunday hitch got here yesterday it’s assembled and In truck now
Just a genos fuel cap. Kind of dissappointed I ordered a locking cap around 2 months ago with the 4/30 back order date and then it changed to September back order date with no shipping notice, so I just ordered a non locking.. oh well
I ordered the same billet locking caps during the 4/30 back-order period. Before mine arrived, the back-order date slipped to September. I did receive my order on May 2nd. They had at least 100 units coming on that 4/30 date, so if your order was early enough, you should still receive them. They are nice caps.
I order the locking caps this morning, fuel cap is out till September. I can wait.
Round 1 last weekend:
Thuren springs and shocks (2.5" front / 1" rear) with King Shocks (on backorder until the 2nd coming apparently.....)
Thuren track bars and front sway bar
Thuren King Steering Stabilizer
Moto Metal wheels (painted in the logo on the edge of the rims) 18x9 +18 offset - with 35x12.5 Nitto Ridge Grapplers
Front windows tinted (25%)
Windshield with ceramic tint (70%) - makes a huge difference with heat, virtually no heat build up in the cab on sunny days (not saying it's not hot, just not burning up)
Debadged - after the pic was taken
Black Fender flares (order power wagon flares but got the wrong part)
Mud Flaps - ordered the std mopar mud flaps and then trimmed them down
Round 2 - tomorrow
Power running boards
Round 3 - Next week
PPF
Vinyl wrap bumpers and rocker panels in black - sort of the Power Wagon look
Round 4 - in June -
Gator Trax MX Retractable Tonneau Cover
Built Right bed organizer (thx RockCrawlerDude)
Round 5 - in June (ish)
4.10 gears with front locker
my wallet hurts....
Genos? Ask them if they have any blems. I bought one when they were out of stock. It had a small scratch on it. Didn't matter as I promptly dropped it after I got it anyway.
Yea, Genos. Thanks for the tip, I reached out to them and just waiting for a reply. Thanks again
I did the same earlier this morning and they responded saying they didn't have any available.
Good to know, here’s to an early delivery
I ordered these back in Feb when they were backordered until April 29th. I called to check on them on April 30. Customer service said they had just arrived from the manufacturer the previous day or so and they would get them right out to me. They arrived here a few days later. The construction and material is first rate. The fit of the DEF cap is perfect. The diesel cap works also but turns harder, is harder to grip and does not rotate quite all the way around to the positive stop like the DEF. But both are securely attached all the same.
Is that an aluminum trailer? Or galvanized?
All aluminum Featherlite and it Is awesome. This is the first I have had. My truck got almost the same MPG traveling 175 miles with this trailer empty as I get without the trailer. It pulls great. I had a really odd load today. There is a golf cart turned perpendicular to the trailer on the very end/tail so I was concerned how it might travel with the long overhang.
Maybe the next load will be a "play" load instead of work. 20210513_175639.jpg
Maybe the next load will be a "play" load instead of work. View attachment 16233
how much does that trailer weigh?
Got my "Aux switches" installed. Had to go aftermarket since the truck was ordered with them, but did not come with them. I got the rough country MLC-6 switches and they worked out just fine. I'm happy with them, but nothing is as clean looking as the stock Aux switches.
I went through the clutch block off plate with the wire pack and attached the switches themselves to the lower dash stack trim piece. That way if I ever want to reverse this I can by ordering those parts, as they are easy to replace and the only thing I drilled holes on.
Next on the list is getting the interior cleaned up again! I've been working every day since getting the truck and just need to stay on top of it better.
